Surging going on with my 6.0 (help) - Ford Powerstroke Diesel Forum
Old 12-26-2010, 01:30 PM
I just picked my 2003 6.0 from our closest Ford dealer about two weeks ago. They installed a new ficum and fixed a few other problems in the wiring. Anyway my truck now has a surging going on when acceleratiing, mostly when it is cold. It has to be completly warm or it will surge. It just about goes away when it is warm. Does it with or without the tune in. I noticed it real bad on the bypass running 75 mph and about 2200 rpm. It never did it before, not blaming on shop, just woundering if something else is starting as soon as i picked up and paid the big bill..lol
Old 12-28-2010, 04:40 PM
Early build motor, check the ICP sensor. I had the exact same problem. It's in the back and is a total pain to get at. Feel for oil on the wiring harness/around the sensor. Should throw a code so check for that before you tear into it if you have access to a reader.
Old 01-01-2011, 10:42 AM
Thanks i replaced that pain in the but just before i put it in the shop. So dont think that is it but thanks again for the help.
Old 01-02-2011, 03:27 PM
The Lady Mod
Send a message via Yahoo to Granny
Did you replace your ICP harness when you replaced your ICP? If not that could be your issue.
Old 01-05-2011, 03:07 PM
No i didnt replace the harness. And it did have alot of oil on it. I did unplug the Egr and it seemed to run a little beter. When the truck is at low rpm or with a little load on it seems to buck more.
Old 01-05-2011, 03:11 PM
By the way Grannie your pic looks familar! I was one wore out dude after that dyno show! But me and the crue had a good time. Hope all is well. Good to here from you.
