Guess What???? 04 F350 NO START - Ford Powerstroke Diesel Forum
Old 12-19-2010, 07:12 PM
Ok lets start
Checked all the connections under the hood and bought connection cleaner and still no start!
Unplugged sensor on passenger side.....no start
Unplugged sensor driver side that connects to exhaust....no start
Had both unplugged no start.
Checked batteries from when it quit and one was bad. replaced it ...... no start
Got the starter checked it is good ..... no start
All sounds that it made before it started under the hood are normal..... no start
RPM gauge never moves at all.............no start
I do have an oil leak that is dropping on the front axle dead center but dont see were it comes from.
Please help with any ideas of what to do next????????
Would anything dealing with glow plugs keep the truck from starting?
Have tired while cold and while its warm out.
Old 12-20-2010, 11:56 AM
Lt. Negativity
OIL PRESSURE. You have an oil leak coming from the front look around the front damper your truck wont start if it doesnt have oil pressure, does the oil pressure gauge move on the dash ? if not that gauge sees 7 psi and it will move if not then theres no pressure. if its an early 04 then it could be hpop did it ever randomly shut off on you ? or cut out and had to restart ?
Old 12-20-2010, 04:59 PM
Yes there was a few times that it was hard to start. The oil nor the rpm guage move at all. How can I check this to be sure. How long will it take to fix. Would love to go to the mountains after christmas but need a way to get there.
Old 12-20-2010, 11:23 PM
mine wouldnt start today but my battery was just dead somehow
Old 12-22-2010, 08:33 PM
Check out video so you can see what I am getting from my baby.
Old 12-26-2010, 09:09 PM
go thru the no start thread in my sig and thank bismic later if it helps you
Old 12-30-2010, 03:44 PM
Send a message via Yahoo to NAFD86
my guess is high pressure oil pump mine did that and would just crank and never get fuel.
Old 01-02-2011, 03:56 AM
Have you tried to plug it in to see if it will start? Might just be the glow plugs.
Old 01-02-2011, 05:51 AM
it could be your ipr valve. if that goes out it will crank and crank but wont fire.
Old 01-02-2011, 06:06 AM
cam sensor?? ur rpms should move when u crank!!
