!! 911 !! TRUCK WON'T SHUT OFF! - Ford Powerstroke Diesel Forum
post #1 of 3 Old 12-19-2010, 08:27 AM Thread Starter
Exclamation !! 911 !! TRUCK WON'T SHUT OFF!
Great first day after getting married
I have an 05 psd and this morning I got in it and turned the key to warm up the glow plugs... the GP light never turned on, edge also didn't turn on like it should whenever I turn the key on. I started the truck and it fired with no problem (despite it being 5 deg outside) I let it warm up about 15 min then while driving it I realized my speedo wasn't working, and none of the info on my edge is changing. Got it home and turned the key off... truck didn't even hiccup, just kept on going, all gauges went to zero tho. Turned the key back on and the start sequence check lights came on then went off like normal, but the truck was running the whole time (still no GP light tho). I tried pulling a number of fuses to kill it such as: "engine control" "PCM" "ignition switch" "ignition switch off/run/start"... but the truck kept chuggin'. I finally pulled the fuel pump fuse and it died immediately. I have to leave that fuse out tho because as soon as i put it back in I can hear the fuel pump running.
My plan now (when time permits) i'm going to remove all my edge stuff (its a juice platinum with attitude A2 monitor) and see if that fixes the problem... if it doesn't, I have no idea what to do next...
PLEEEAASSEEEE HELP!
Thank you TONS in advance for any advice
Montana250 is offline
post #2 of 3 Old 12-19-2010, 09:39 PM Thread Starter
UPDATE:
So I pulled out the edge module and plugged the factory plugs into the factory sockets. I put the fuel pump fuse back in and it doesn't run without the key on (good sign) and the glow plug light comes on with the key (also good sign) but, since the engine control systems clearly never shut off earlier, my batteries are dead, so I can't even try and start it. Put the charger on there and i'll update again after I let 'er charge for a couple hours.
post #3 of 3 Old 03-02-2011, 09:07 AM
I had to remove my Edge too, Edge told me that ford had basically made it obsolute right after I bought it and that it was bad that I had continued to drive it.
Offered to sell me a new one for 700, no more Edges for me.
digesterman is offline
