HPOP Cover Removal
I have an 05 f250 and I am changing the STC fitting to the HPOP...how in the heck do I get those bolts out of the cover that are under the EGR cooler? Do I have to remove the EGR cooler? Does anyone know of a step by step that might help me get this done? Thanks for any help you can give me.
Remove the upper exhaust manifold to up-pipe nut and bolt on each side. Remove the EGR cooler to up-pipe clamp. Move the entire y-pipe assembly rearward (toward the firewall) as far as it will go. Finesse the high pressure oil pump cover out with the three bolts in the cover, using extreme caution so as not to let them drop into the engine. Once the cover is removed far enough that any one or all of the three bolts can be accessed, remove from the cover right away. Proceed with cover removal using finesse.
thanks mchan...s'ok. I know you work with hideous female employees. You don't have to say it.
no it was even more funny before he edited it
![]() someone saw it from his work place. |
