need help, truck wont start - Ford Powerstroke Diesel Forum
post #1 of 3 Old 12-14-2010, 10:37 AM Thread Starter
I have a 2006 6.0L kingranch, i had a remote start installed last week, i got it back ran fine, remote starter worked great, friday when i went to use it it would not start. I had my batteries tested they were dead, so i replaced my batteries and tried starting. It did not start at first but it ended up starting up, i let it run for a little then turned it off, and turned it back on and started up no problem, and drove it the rest of the day and it was fine. Yesterday i go to start it and it would not start, it is cranking but will not start. Any help would be great. Thank you.
Jcahill is offline
post #2 of 3 Old 12-16-2010, 05:40 PM
superjet701k's Avatar
weak or very low batteries will kill a ficm. you need to test ficm voltage it should be 46-48 volts if not she will not start esp when cold. if bad have it rebuild buy someone on this forum i read he can build them better
superjet701k is offline
post #3 of 3 Old 12-17-2010, 07:30 AM
Chango's Avatar
no start thread in my sig. good luck!
Awesome thread on oil / cold start issues for 6.0 ---->
Troubleshooting a no Start Condition --->
Still using Ford Coolant? ---->
Chango is offline
