Is my FICM bad? - Ford Powerstroke Diesel Forum
Old 12-13-2010, 03:25 PM
Is my FICM bad?
Trying to diagnose whats wrong with my truck, so i just wanted to get some opinions
The symptoms are:
-Rough start at anything lower than 40-ish degrees, i have to roll the keys about 3 times and sometimes hold the RPMS around 1000 otherwise it will die
-While warming up from a cold start, every once in a while it lopes a bit (probably every 10 seconds or so until its warm). The idle will drop for a fraction of a second than catch back up to normal idling.
-Fairly noticeable turbo lag
The truck also used to misfire around 65mph/1800 rpms when driving through the mountains here, but it hasnt done that since i've ran 5000 miles worth of rev-x through it
I just scanned the truck on a cold start with an obd2, and got nothing.
Im planning on putting a straight pipe exhaust system and hopefully some custom tunes here in the near future, but i figured i better find out whats going on first.
Old 12-13-2010, 03:29 PM
and if it matters at all, this is an 03 6.0L
Old 12-13-2010, 09:56 PM
bump?
I guess i'll just read my voltage in the morning.....
