mystery sound on my 05 6.0 - Ford Powerstroke Diesel Forum
Old 12-13-2010, 03:04 PM
It's been driving me nuts and costing me fuel and power. Anyone got any ideas? Read the description. Thanks for your time!
Old 12-13-2010, 03:15 PM
sounds like a boost leak to me, is the boost hitting is normal psi? is there any excessive somke? turbo having issues? tranny feel normal all that jazz???
Old 12-13-2010, 03:46 PM
It used to hit 30ish psi before but now it maxes out at 20-22ish. Not much smoke and the tranny feels ok. I've looked for leaks but can't seem to find em, do you know any tricky spots? Thanks skooter!
Old 12-13-2010, 04:01 PM
the boot that goes on the turbo for the charge pipe cracked on the back mine. best way i found to find boost leaks is take all the boots off visually inspect them if they check out ok make sure your getting a tight seal on them but dont over torque the clamps cause it will tear the boots and make em leak.
