Coolant/Oil leak?
So I've had an oil leak for a few months now...its mainly running down the left side of the bell housing and dripping down. Well today at work after the truck has sat in 30* weather for about 5 hours it started leaking coolant...from the exact same spot on the bell housing. Like...the coolant was landing in the exact same spot as the oil. Once I started the truck and got it warm the leak stopped....
The coolant bottle has been removed/installed about 6 times this year due to injector work (we all know about that)...dunno if that has anything to do with it though. any ideas? |
do you have a coolant filter?
Nope no coolant filter...
Oh, and the truck has 153k miles on it. Its been run hard here lately, 1600 miles for a trip to texas, and 1700 miles for the trip i took to indiana. Within a 2 month span. |
sounds like it just leaks under pressure before the t-stat opens.. i would check the hoses to the heater core first... there is a coolant line the runs over the motor on the upper firewall that might be leaking.... or check the hose that runs to your egr cooler if you have one...
