?? How to drain fuel/water seperator?? - Ford Powerstroke Diesel Forum
Old 12-09-2010, 05:52 AM
I received a water in fuel light on my 05 f250 so like a good little boy I went to the ford book. After looking at the sparse instructions I found the horizonal mouted fuel filter, but for the life of me, I could not find the drain lever that is referenced in the book. Has anyone else had to drain the water seperator on a 6.0L? If so, what is the best way to do it?
I know I must be over looking something, but what??
Old 12-09-2010, 06:11 AM
On the HFCM there is a plug, in the center bottom of the HFCM cover. Remove this plug to drain the HFCM. Be prepared to take a diesel bath though. I use a lot of news paper, aluminum foil to direct the flow and rags.
Old 12-09-2010, 06:18 AM
<-Day Of Fail now SOLD
Take a look at this pic, behing the heater wire is a copper plug that you remove.
Page 29: Fuel Supply System
Old 12-09-2010, 06:45 AM
i cut a milk jug up and use that to catch the fuel, never spilt a drop on me.
Old 12-09-2010, 07:15 AM
Thanks, for all the great help and info.
And great visual aids
Old 12-10-2010, 06:59 AM
If you have the same problem that I had, with the previous owner stipping out the 6mm alan key get one of these makes draing soo much easier.
HFCM Drain Plug at DieselManor
