A/C and Heater vents not working right - Ford Powerstroke Diesel Forum
Old 12-03-2010, 07:11 PM
The only place where air will come out is on my defrosting vents. If I switch it to go to my feet or face it will still only come from the defrosting vents. Anyone ever had this issue?
Old 12-04-2010, 07:44 AM
vacuum leak... check the pump and hoses, they go to the hubs as well.. might have a cracked or broken line...
Old 12-04-2010, 03:38 PM
had the same problem. its a vaccum line. the vaccum pump is right by where you put the oil in the engine, there will be a round black object just above that, check and see if there is a grey hose on it, if not, look for it and pop it back on there.
Carl
