need some help please..
my friend has an 04 with 150k on it. it started running crappy, no power, hard cold starts, sluggish ect. He took it to the dealer and they said it was the egr valve, they cleaned it and put it back in, but it had little change.
we just got done doing oil changes on both our trucks tonight, (rotella t5). With all the searching and reading i have done the past few months, i am a big believer in watching the eot and ect's, and we both plan on changing to elc asap!! He hasn't had any real problems with the truck, just maintenance stuff and this egr issue to this date. original owner so he knows everything about the truck. no signs of overflow at degres bottle, but we were curious of temps, with how any miles he had and no real issues... He is going on a few hour trip for thanksgiving so i gave him my edge evolution to monitor his temps. the edge flashed 4 codes!! p0275 cylinder 5 contribution/balance fault p0281 cylinder 7 contribution/balance fault p0284 cylinder 8 contribution/balance fault p0528 fan signal malfunction so we are worried about the first 3, 4th we can check wires and fan not an issue.. what does contribution/balance fault mean?? is this a compression issue, injector issue or what?? what should we check/do do fix/diagnose? why didnt the dealer find these codes? Thanks in advance.. |
needs 3 injectors, fuel pressure regulator
thanks, thats what i was worried about..
with 150k miles, should we replace all 8, or is it ok to just replace the 3 bad ones? |
Do all 8 with that many miles on them. No sense in having to do it twice, when the others start to crap out on you.
Besides that point, does it hurt or effect anything if he didnt change all of them? I guess is my real question. |
It won't hurt anything, per se, other than performance. As they start to wear out, they won't be able to generate as much injection pressure.
so if we only change the three, and the others aren't "performing", will he start throwing the injector codes again? even though they arent bad per say, but not not balanced, or fully contributing?
thanks for the info! |
Not likely that bad. It could be but not likely. It would be better to have them matched so that they equally perform, but won't be enough to cause the contribution code.
