Leaking oil,rough idle and shift,low boost. - Ford Powerstroke Diesel Forum
post #1 of 4 Old 11-06-2010, 11:35 AM Thread Starter
reconsniper1's Avatar
Location: North Pole Alaska. Yes it is not a joke. NP AK really exists!!!
I have a 2004 6.0 with just over 113k. I recently noticed an oil leak that seems to be coming from the top rear of the motor and dripping down to the oil pan. I did research and found that it is probably an hpop gasket. Well lately I have noticed a difference when it idles,acceleration is slow and there is no power,my turbo has some severe lag until I hit 2000 rpms or more. During acceleration I feel a bad jerk when the trans shifts. I am guessing this is because the engine isn't running right. It is going in the shop next week but I am just wondering if this could all be from a leak?
reconsniper1 is offline
post #2 of 4 Old 11-06-2010, 11:47 AM
Jonboywv12's Avatar
Send a message via AIM to Jonboywv12
i really dong think it is a hpop gasket. it could very well be a rear main seal, though they are not know to fail every so often there will be one that does. or it could be o-ring on the turbo that could have dry rotted or just gone bad as well. that is a more common one to have happen.
Jonathan or Jon
2002 F-350
4" Banks turbo back exhaust.w/5" tip
4" Banks down pipe
Banks Big Hoss turbo waste gate
6" SKY JACKER
35" Nitto All-Terrains
TW chip 6 pos.
Banks Trans-Command shift kit
AFE STAGE II Intake
Gauges (boost, EGT)
102" whip antenna (guaranteed 100hp!
enough for fun!
Jonboywv12 is offline
post #3 of 4 Old 11-06-2010, 02:12 PM Thread Starter
Those were the other two I was told it could be. It is going in the shop next week,I think it is covered under my warranty. After taking a closer look today I believe it may be the turbo. There is alot of oil residue on the bottom side of the turbine housing. How much do you think it would be to have that replaced if it is not covred under warranty? I know the ford dealership is really proud of their brand.
post #4 of 4 Old 11-06-2010, 09:11 PM
Jonboywv12's Avatar
well if it really is the o-ring on the turbo you could do that your self if you were so inclined to do so for pretty cheap...the o-ring and bolt to go into it will run probably 25-40 bucks, if you were doing it yourself...knowing ford, labor+Parts=$$...so i cant really give you a real price on everything
Jonathan or Jon
2002 F-350
4" Banks down pipe
6" SKY JACKER
TW chip 6 pos.
AFE STAGE II Intake
Gauges (boost, EGT)
enough for fun!
