Wheres my A/C? - Ford Powerstroke Diesel Forum
Old 05-16-2007, 06:20 PM
Wheres my A/C?
Hello everyone,
My problem is that my A/C wont always blow cold. I was told it needed frion but when they checked the preasure it was right where its suppose to be. I live in Texas and in the summer its usally gets in the mid to high 90s ocassionaly hitting the triple digits! Any help would be greatly appreciated.
Old 05-16-2007, 06:33 PM
did you try cleaning your condenser??
Old 05-16-2007, 07:15 PM
Could be a vacuum line.
Old 05-16-2007, 07:27 PM
Where exactly is the condenser, and how can I check the vacume lines.
Old 05-23-2007, 05:38 PM
Does anyone know where its at?
Old 05-23-2007, 06:16 PM
your condenser is sitting in front of your radiator.
Old 05-23-2007, 06:32 PM
What about the vacume lines
Old 06-04-2007, 06:19 PM
Is the clutch on the compresor working when not cooling? if not unplug and inspect plug. My truck did same thing last fall when it was in the 100's. the plug was burnt on one of the wires connection and ford has had this problem because they had a new plug with connectors and shrink tubing for a water tight connection. took about ten minutes to fix. o problems since.
Old 06-04-2007, 06:38 PM
Check the air blend doors under the dash and check the vacuum lines that work them. you could have something hanging up the blend doors.
Old 06-04-2007, 06:58 PM
Check for power @ the a/c compressor plug, and if you have power, the compressor clutch should kick in. If it isn't kicking in, try to lightly tap on the face of the compressor clutch with a small hammer. If it kicks in you probably have a shorted pull in coil on your compressor clutch. You might also check the pressure switch on your reciever/dryer as they like to fail as well. Also, try blowing out your condenser, if it is plugged with debris it will not change the state of your refrigerant because it can't dissipate the heat fast enough.
