2005 F250 6.0 Wont Start Please Help!!! - Ford Powerstroke Diesel Forum
post #1 of 38 Old 06-16-2010, 06:25 AM Thread Starter
I owe 2005 F250 which is Stock.. This issue started couple of months after I had my batteries replaced… Batteries were going out so I jumped it one or two times and went to ford and bought two brand new batteries and replaced them… Truck ran fine with no problems, couple of months later I started having issues with starting up the truck, I will drive it fine come to the store turn it off came back from the store turn it back on and it will not start, batteries have plenty power, it turns over fine, no engine codes it appears like it’s not getting fuel, it appears like it wants to start but then it will start up for 10 second work on 100 to 200 RPMs very low and turns off. I tired starting it couple of times and it once it starts it starts fine, run perfect no power loss or anything. Well that started happening more often and sometimes it does not won’t to starts right away I have to let it sit for couple of hours and then try it again and then starts perfect again. I change my oil regularly, change oil and fuel filters, I have also cleaned my EGR valve….. Could it be my Fuel Pump or could it be FICM?? Thank you…
0CooL is offline
post #2 of 38 Old 06-16-2010, 06:42 AM
Unapologetically American
2006PSDSD's Avatar
Quoted: 24 Post(s)
Feedback Score: 4 reviews
I'd say FICM. I'm no expert though
Is it more of an issue when the engine is warm, or does that not make a difference?
2006 F350 SOLD
* KMC XD Monsters wrapped in Hankook ATM's
* 08 style mirrors
* 4" TB exhaust
* SCT X2 with Gearhead, PHP and ID tunes
* Edge Insight CTS
* Blue FPR spring
* 6.4 Banjos
* Dfuser coolant filter
* Stage1 MTW turbo
New truck has a Cummins and a handshaker
2006PSDSD is offline
post #3 of 38 Old 06-16-2010, 06:51 AM
Slacker
Evil Eye's Avatar
Quoted: 190 Post(s)
It could be a bunch of things, but I would lean towards a High Pressure Oil leak at the STC fitting. Do you have a diagnostic tool to measure ICP, ICP demanded, IPR duty cycle and FICM voltage while cranking? This will help you determine which system you need to look at more closely.
Shawn Carlson
Proud Navy Vet
2005 F250, CCSB, 6.0 PSD, FX4 (The Sweet Unit is white)
2008 F350, CCLB, 6.4 PSD (Brad-the wife's truck is black)
Engine Mods:
Fluidampr
CCV Reroute (Reinstated)
4" MBRP Exhaust
MTW Stage 1 Turbo
Bulletproof 53V FICM
BulletProof EGR Cooler
BulletProof Water Pump
Riff Raff Intercooler Boots
Gogo Diesel Direct Drive Solenoid
BulletProof All-Aluminum Radiator
BulletProof All-Aluminum Intercooler
BulletProof Oil Cooler System w/ Bypass Filter
SCT w/ Custom Tunes (TSD, DJ's, Innovative, Gearhead, QuickTricks)
Exterior Mods:
Bilstein 5100 Shocks
Icon Adjustable Trac Bar
Firestone RideRite Air Bags
BDS Dual Steering Stabilizer
Aluminum Finned Differential Cover
Reese 16k Manual Slider 5th Wheel Hitch
Icon 2.5" Leveling Kit w/ F-350 rear blocks
20" BMF Novakanes wrapped in 33" Nitto Terra Grapplers
Evil Eye is offline
post #4 of 38 Old 06-16-2010, 07:17 AM Thread Starter
it's more when the engine is warm.....it starts up good when it's cold
0CooL is offline
post #5 of 38 Old 06-16-2010, 07:19 AM Thread Starter
I do not have the tool, i can take it to the dealer and let them scan it...
0CooL is offline
post #6 of 38 Old 06-16-2010, 07:19 AM
Slacker
Evil Eye's Avatar
Quoted: 190 Post(s)
Definitely sounds like STC fitting on the High Pressure Oil Pump.
Shawn Carlson
Proud Navy Vet
Engine Mods:
Fluidampr
4" MBRP Exhaust
MTW Stage 1 Turbo
Exterior Mods:
Evil Eye is offline
post #7 of 38 Old 06-16-2010, 07:19 AM
2006PSDSD's Avatar
Quoted: 24 Post(s)
I'd do what Shawn said then, check oil pressures when the problem happens. STC fittings go out somewhat regularly, and they now have an updated fitting for a remedy
2006 F350 SOLD
* 08 style mirrors
* 4" TB exhaust
* Edge Insight CTS
* Blue FPR spring
* 6.4 Banjos
* Stage1 MTW turbo
post #8 of 38 Old 06-16-2010, 09:54 AM Thread Starter
Should I just go ahead and replace the STC fitting with the updated kit that I have read about on the forum here kit # 4C3Z-9B246-E (does anyone have step by step installation for this kit). How do I check my oil pressure?
0CooL is offline
post #9 of 38 Old 06-16-2010, 10:19 AM
2006PSDSD's Avatar
Quoted: 24 Post(s)
You'll need a scan tool to check it
2006 F350 SOLD
* 08 style mirrors
* 4" TB exhaust
* Edge Insight CTS
* Blue FPR spring
* 6.4 Banjos
* Stage1 MTW turbo
post #10 of 38 Old 06-16-2010, 12:34 PM
Powerstroke Techie
m-chan68's Avatar
Quoted: 3 Post(s)
Which has now been superceded to 4C3Z-9B246-F to include new IPR valve screen and o-rings.
Ford Diesel/Senior/Master Tech who placed 2nd overall in Ontario on the Fix-It-Right-First-Visit score for 2010
....who works at a dealership that now employs SOME half decent looking female employees since they overhauled most of the administrative staff
....but STILL loves hot women with big boobies
....and STILL hates working on E-Series with 6.0L
m-chan68 is offline
