05 F-250 6.0 Stroker NO START!
Have an 05 6.0 Powerstroke, ran rough and died. Will crank and try to start but never runs. Changed both fuel filters, left the cap off the secondary fuel filter and turned the key on and get nothing but air. We pressured up the fuel tank and cycled the fuel pump several times till we got fuel to the secondary filter. Cranked and finally started engine and ran for a few minutes and slowly lost rpm and died. Pulled the secondary filter again and it had no fuel in it. It is showing no codes, any one have any ideas?
You need to get a fuel pressure gauge hooked up to the test port on the secondary fuel filter. You should have about 55psi at an idle. If you don't have the pressure then it's probably your HFCM on the driver side frame rail (which is your fuel pump). If you do have correct pressure you have a problem on your oil side.
Appreciate the help, i will give that a try and let ya know how it goes.
Fuel pump on the frame rail was the problem. Thanks for the help
