Intake removal question. HELP!
Ok guys I am so close to getting the intake off but the darn wire harness is in the way. I am not sure of the best way to get this out of the way. I don't want to just go randomly unplugging everything. Can any of you who have done this before make any suggestions?
Is it the harness that is connected to the intake itself? If so, just unscrew that bad boy. It's simple!
Neh, it goes across the manifold. From the FICM to (I think) the glow plugs.
There are two harnesses that cross the intake. The harness from the FCIM to the injectors has to be unplugged at the injectors and moved out of the way. The other harness will have enough play to pull the intake out as long as most of the connectors are undone.
