06 6.0 died - Ford Powerstroke Diesel Forum
post #1 of 13 Old 04-30-2010, 05:42 PM Thread Starter
06 6.0 died
I have an 06 6.0 f-250...was running great and just died on the side of the road...I have replace crank sensor and fuel pump so far...also pulled the ficm and checked the solder joints....they appeared fine but I reflowed them anyway....codes when it died were low injector current on all 8 cylinders.... voltage on the ficm is about 26 when you turn the key on but 48.5 after 10 seconds or so....and 48+ while cranking on the engine....what am I missing...does anyone have any ideas????
Hlewis is offline
post #2 of 13 Old 04-30-2010, 06:21 PM
97Beast's Avatar
Quoted: 13 Post(s)
Not sure about the FICM and injector codes. But my neighbor a while back blew his STC fitting on his truck, this fitting is some sort of fitting in the oil system (i think). His truck was running fine until he went back outside to start it up, and it wouldnt start.
The STC fitting is a big problem with the 6.0ls especially on the earlier models although his is an '06 also.
John
'97-F-250 PSD CCSB 3.55s E40D, Dana 60, PMF 2.25" RSK, U Code SD Springs, 315/75/16 TerraGrapplers, Tow Mirrors, Colibert Tow hooks, RDS Stage 1s, PHP 80hp, RiffRaff 6637, 3"DP, 4" Exhaust, 6" Tip, Power Front Seats, Rear 40/20/40, Explorer OHC and Autolamp Rearview, EATC, Cree LEDs & more
'89-Bronco 5.0l 33"s Free flowing exhaust, 06 SD power seats, & more (SOLD)
'80-M35A2 "Deuce 'n a Half" W/winch Multifuel Soft top
97Beast is offline
post #3 of 13 Old 04-30-2010, 06:25 PM
Peppy's Avatar
i had the same thing happen to me ficm was my issue, sounds like yours aswell
04 f-350 sc lb
4"Silverline TB exhaust straight piped
tunes by Cale
Smoked tails
305/70/16 Grabber AT2
05 headlight conversion
Compustar 2way starter
Peppy is offline
post #4 of 13 Old 05-04-2010, 06:55 AM
I had the same problem on my '04. It was the Accelerator position sensor. Unplugged and plugged it back in, been running fine since.
'04STROKE is offline
post #5 of 13 Old 05-04-2010, 08:15 AM
azkcr's Avatar
Quoted: 3 Post(s)
I'm putting my $$$ on the fitting. It's right next to the HPOP (high pressure oil pump)..
I'm about to have to pull mine too.
Ben Conner
LSP Assistant Director
Got every PSD made...
My DD: '13 6.7L with Optimus Prime's wanker still on the exhaust
azkcr is offline
post #6 of 13 Old 05-04-2010, 12:09 PM
Slacker
Evil Eye's Avatar
Quoted: 210 Post(s)
Feedback Score: 4 reviews
Your FICM is bad or you still have a poor solder joint which is causing your issue.
His is an 06, so the STC fitting isn't likely. Additionally, a faulty STC fitting wouldn't give you ANY diagnostic trouble codes... Ask me how I know...
Shawn Carlson
Proud Navy Vet
2005 F250, CCSB, 6.0 PSD, FX4 (The Sweet Unit is white)
2008 F350, CCLB, 6.4 PSD (Brad-the wife's truck is black)
Engine Mods:
Fluidampr
CCV Reroute (Reinstated)
4" MBRP Exhaust
MTW Stage 1 Turbo
Bulletproof 53V FICM
BulletProof EGR Cooler
BulletProof Water Pump
Riff Raff Intercooler Boots
Gogo Diesel Direct Drive Solenoid
BulletProof All-Aluminum Radiator
BulletProof All-Aluminum Intercooler
BulletProof Oil Cooler System w/ Bypass Filter
SCT w/ Custom Tunes (TSD, DJ's, Innovative, Gearhead, QuickTricks)
Exterior Mods:
Bilstein 5100 Shocks
Icon Adjustable Trac Bar
Firestone RideRite Air Bags
BDS Dual Steering Stabilizer
Aluminum Finned Differential Cover
Reese 16k Manual Slider 5th Wheel Hitch
Icon 2.5" Leveling Kit w/ F-350 rear blocks
20" BMF Novakanes wrapped in 33" Nitto Terra Grapplers
Evil Eye is offline
post #7 of 13 Old 05-04-2010, 12:51 PM
azkcr's Avatar
Quoted: 3 Post(s)
Search STC fitting and see how well they hold up compared to the threaded.. Not a whole lot better. Mine is an '06 and guess what I'm replacing? Yup. STC fitting..
But it not throwing a code would make sense. (too lazy to read. lol)
Ben Conner
azkcr is offline
post #8 of 13 Old 05-05-2010, 07:43 AM
Slacker
Evil Eye's Avatar
Quoted: 210 Post(s)
Did it end up being the STC fitting? Sounds like it was your oil screen...
PS. if your oil screen was torn, you should check your IPR as well and make sure it isn't clogged with junk, too.
Shawn Carlson
Proud Navy Vet
Engine Mods:
Fluidampr
4" MBRP Exhaust
MTW Stage 1 Turbo
Exterior Mods:
Evil Eye is offline
post #9 of 13 Old 05-05-2010, 11:16 AM
azkcr's Avatar
Quoted: 3 Post(s)
Indeed it was sir. It wasn't torn, just clogged as hell..
But search around and you'll read that the STC fitting is not much better in a lot of ppls eyes..
And IPR was 2nd thing checked.
Ben Conner
azkcr is offline
post #10 of 13 Old 05-05-2010, 11:56 AM
Slacker
Evil Eye's Avatar
Quoted: 210 Post(s)
Good deal. My screen was torn as was my IPR, so whatever tore my screen also put a tear in the IPR. BTW, I have been through all the "fixes" for the STC fitting so I have personal knowledge on how unreliable it can be...
Shawn Carlson
Proud Navy Vet
Engine Mods:
Fluidampr
4" MBRP Exhaust
MTW Stage 1 Turbo
Exterior Mods:
Evil Eye is offline
