problems need help - Ford Powerstroke Diesel Forum
Old 04-17-2010, 02:44 PM
problems need help
I have an 04 F250 it won't shift in to 4 low most of the time and i have a problem getting it to shift in to gear from park .You have to stab the break 2or 3 times before it will come out of park with it running .Also sometimes i have to turn the key on just enough to get it out of gear and start it in neutral. any ideas
Old 04-17-2010, 02:49 PM
Send a message via MSN to dusted4eva
I think you need some linkage adjustments.
Old 04-17-2010, 02:56 PM
bolth items are electrial problems or pressure opperated i think i dont understand how it all works yet.
Old 04-17-2010, 03:06 PM
Try this
http://www.fordforum.com/forum/showthread.php?t=11465
Old 04-17-2010, 03:36 PM
Thank you ill check the torx bolts first i had the same problem with the bolts on a 150 work truck and had to replaice the shift tube on it.any ideas on the 4wheel drive
Old 04-17-2010, 03:38 PM
Maybe the shift solenoid. Not sure.
Old 04-17-2010, 03:52 PM
ill check it out and post back
