Pro-long cranking before starting - Ford Powerstroke Diesel Forum
Old 04-17-2010, 03:15 AM
My 2006 Diesel spins over for a long time before starting after sitting for a long time, say over night or all day while at work. When starting after a quick stop it fires right up. I'm trying to discover what can cause this so I "don't spend a weeks vacation money for someone to seek and find". Any help would be greatly appreciated.
Old 04-17-2010, 05:01 AM
I have the same problem. Someone told me to check all my ground connections and my connections at my starter, haven't done it yet, but it sounds like it could be the problem.
Old 04-17-2010, 06:47 AM
I am having the same problem now after I got the truck back from Ford. They did a new FICM, injectors, egr cooler, oil cooler and egr valve. Since the work (no problems before it went it just did it before the warranty ran out) I have had this EXACT problem. I have been told that maybe I got a bad FICM.....or the SCT valve is going bad.
Old 04-17-2010, 07:37 AM
same here
I took mine in for a new egr cooler and since I got it back it started this.
Old 04-21-2010, 11:26 PM
might be a high pressure oil leak,
Old 04-22-2010, 05:29 AM
had the same problem, batteries were weak and the FICM was bad. replaced the batteries and got the FICM under warrenty. much better now.
Old 04-22-2010, 11:57 AM
Yep weak batteries will cause the truck to take longer to start. I replaced mine and my truck kicks over in about 2 - 3 seconds.
Old 04-22-2010, 12:06 PM
Nice rig by the way... is that a RMK hanging out the back?
Where do you live?
Old 04-23-2010, 06:35 PM
Another 6Slow
mine is doing the same thing ford says that its a high pressure oil leak somewhere but they cant find out where they had it for a week and when i went to pick it up thats what i was told lol...
