HELP - Check Gauges and Electric Throttle Control light...
Need help in understanding 2 indicator lights that are coming on.
1) "Check Gauges" message It appears where the odometer is. It mostly comes on when I press the brakes, and even moreso when it's rainy out. It's not constant. 2) "Electronic Throttle Control" which is the wrench indicator light After driving 1000 miles with issue #1 happening less frequently than not, today I got the open-end wrench indicator light on the dash that stays on without the message outlined in #1. I checked the manual and this idicator says it's the Electronic Throttle Control. A guy who works on the truck for me says issues #1 is being caused by a bad front brake sensor and that issue #2 requires replacing some module or part of which reads all these sensor messages. Note: just had it at the dealer who did 7 flash updates. Rough/cold start went away and ran bullet-proof #1 started on Thur in the rain and today #2 happened. HELP! Last edited by Pathfinder22; 04-01-2010 at 03:11 AM. Reason: added pic, typos |
any help is appreciated! thanks alot.
Look at the pic your oil psi is at zero and the truck is running cause I see rpm's. The sending unit is an on/off style, if it reads 6 psi its in the normal position if under 6 psi dead stick. I have the same issue with a bad wire to the sending unit. That is why you get the check gauge message, not sure about the other.
Thanks Tyler - just making sure and the guy I bought the F250 from is going to replace the gauge and whatever needed with sending unit.
As for the wrench indicator, that came on ONLY once and I'm still perplexed over it. The manual did have much detail about this indicator. Oh well guess I better start getting use to these kind-of hiccups with the 6.0L PSD, and here I thought things were solid after the dealer updated with 7 necessary flash updates which cured my cold start/rough idle 110%......ARGH!!! |
Where are you located maybe someone close by can pull come code for you, and give you a better idea why the wrench light is on.
I live in Jensen Beach, FL which next to Stuart, FL.
What device can I purchase that will allow me to pull codes and become familiar with Do-It-Yourself fixed OR at least be more intelligent when it comes to taking to a shop?? Still seeking advice from this forum for a top-notch PSD/6.0L/Diesel repair shop in my neck of the woods....otherwise it seems that First Coast Diesel in JAX is my next stop. |
Several members have AutoEnginuity PC Scan Tool, works well when chaseing ghost. Only down fall is you have to learn how to use it good.
AutoEnginuity PC Scan Tool (USB) Here are a couple things to read, don't worry its really not that much most of the info is in there twice. My self several mods and members have more links if ever want them. All you have to do is ask. Powerstroke 6.0L Technical Intro Manual 6.0L Bible Table of Contents 06-21-2 Coolant Degas Bottle Overflow - 6.0l 6.0L EGR Maintenance and Cleaning (Write-Up) Cleaning Turbo |
