egr install issue/exhaust - Ford Powerstroke Diesel Forum
Old 03-28-2010, 03:20 PM
alright well i got everything apart and everything together EXCEPT the y pipe to the turbo that i cant get to fit back together correctly so i attempted to just crank the clamp down still leaked so i cranked it some more... then the clamp came apart so what is the trick everything else is tight and good except that any thoughts???
Old 03-29-2010, 08:53 AM
Seems like there has to be something in there, I would say take off the clamp and check all the way around for something in the way. Mine has a little tab at the top to help hold it together, did that get bent? Does the pipe line up properly?
Old 03-29-2010, 01:42 PM
nothing is bent but i broke the clamp and it doesnt have a tab on it but im going to loosen up the up pipe and y pipe and try to take that angle
Old 03-29-2010, 02:00 PM
Illiana Chapter Director
Yeah, loosen the clamps and also loosen the turbo mounting bolts and see if the turbo moves a little. Reinstall the new "y" pipe clamp and see if everything lines up, tighten the turbo mounting bolts and then the clamps. All should be good.
Old 03-29-2010, 02:36 PM
When I did mine, I had the same problem. Loosened the passenger and driverside exhause manifold bolts, to the up pipes, to give enough play in the y-pipe at the turbo. Be careful with the y-pipe. I messed with mine so much I think I made the pin hole a major leak. No exhause leak before break down, major leak once back together. Replaced the y-pipe and everything is great. The driver side exhaust manifold bolts are a pain!
Old 03-30-2010, 06:57 PM
I had the same problem with mine and I finally took the mounting bolts out of the turbo and bolted the y-pipe up. Then bolted the turbo up and no leaks!
Old 04-21-2010, 11:07 AM
take 2 minutes to take your driver side fender well out and ur pain becomes easy.
Old 04-21-2010, 12:49 PM
Feedback Score: 5 reviews
I just had to loosen the y pipe and put a new clamp on and everything went together well then just retightened everything
