Fuel pressure (not sure if its a problem) - Ford Powerstroke Diesel Forum
Old 03-26-2010, 05:14 AM
I finally got some of my gauges in. My fuel pressure sits at around 50-53 at idle. But under full throttle drops to about 48. It never goes over 55 that I have seen. New Ford filters a couple weeks ago... I've read 45 is the max on the low side, and I'm close. But I've read others up to 60 or so in the high side. I have no tunning yet,or chips so I wonder if this is normal for stock.
Old 03-26-2010, 05:19 AM
Feedback Score: 5 reviews
ford spec is 50 psi +/- 5psi, so you are within spec of optimal fuel pressure.
Old 03-26-2010, 05:27 AM
Powerstroke Techie
Ford spec as per the latest & greatest PC/ED Performance diagnostics worksheet is F-Super Duty/Excursion 310 kPa (45 psi) MIN - 503 kPa (73 psi) MAX.
This is tested at full load/WOT or using the proper Rotunda SST with the special calibrated orifice to simulate full load.
Old 03-26-2010, 05:29 AM
Powerstroke Techie
There is a new fuel pressure regulator available for the 6.0, 3C3Z-9T517-AG. It comes with a blue spring and bumps fuel pressure to around 70psi, 50-55psi with the test tool (as mentioned in the above post) valve open. Hope this is of some use to you. Typically I will put a small ball bearing under the spring, or put a different spring in it should I be able to find one that fits well and doesn't put the pressure through the roof.
