How do i disconect the seatbelt chime on my 2006 f250
the procedure to do this is in your manual. I've done it to both my superduties. I'm at work right now, but tomorrow when I'm home I'll check back to see if you got it solved. If not I'll pm you with the procedure.
and BTW, welcome to the forum!!! Last edited by shu873; 04-23-2007 at 06:58 PM. Reason: forgot my manners again |
From the 2007 manual. Should be the same fo a 2006.
BeltMinder activation and deactivation procedure 1. Turn the ignition switch to the RUN (or ON) position. (DO NOT START THE ENGINE) 2. Wait until the safety belt warning light turns off. (Approximately 1 minute) • Step 3 must be completed within 60 seconds after the safety belt warning light turns off. 3. At a moderate speed, buckle then unbuckle the safety belt 9 times, ending with the safety belt in the unbuckled state. • After Step 3 is complete, the safety belt warning light will be turned on for 3 seconds. • If Step 4 does not occur within 10 seconds at the end of Step 3, BeltMinder will automatically exit programming mode without changing its enable status. 4. Within 10 seconds of the light turning on, at a moderate speed, buckle then unbuckle the safety belt. • This will disable the BeltMinder feature if it is currently enabled. As confirmation, the safety belt warning light will flash 4 times per second for 3 seconds. • This will enable the BeltMinder feature if it is currently disabled. As confirmation, the safety belt warning light will flash 4 times per second for 3 seconds, followed by 3 seconds with the light off, then followed by the safety belt warning light flashing 4 times per second for 3 seconds again. 5. After receiving confirmation, the deactivation/activation procedure is complete. Jay |
Thx outlaw! You saved me the trouble tomorrow.
Hey oops.. interesting name.. looks like these guys already got you hooked up with the info you were wanting.. so I'll just say:
Welcome to Powerstroke.org
I've got a copy of the manual in PDF, so it's easy to cut and paste.
Jay |
thank fore the help guy's
Wonder if this will work for my 04. Man I hate that darn bell!!! hehe
Shawn, I've had an 04 gasser, an 05 and 06 diesel. The procedure has been the same for all of them. You should be good to go!
Does this permenatly disable the chime? I just disconnected the electric plug under the seat.
