Water In Fuel - CORROSION - Ford Powerstroke Diesel Forum
post #1 of 6 Old 03-19-2010, 07:21 PM Thread Starter
jconway's Avatar
Exclamation Water In Fuel - CORROSION
I need some advice, and I know that someone out there can give me some input on this situation.
About two months ago I noticed the "Water In Fuel" light for the first time. I spoke with a guy at work, and he told me just to put diesel treatment in my tank, and that the problem would go away. The light would come on a few minutes after I started my engine, and when I would reset the codes, it wouldn't come back for a while. Of course all this was before I knew about the water separator under the driver's side door.
I noticed corrosion in my fuel tank filler neck yesterday at the gas station. That got me extremely concerned, so I did what any normal dude would do...sign on to powerstroke.org and do a quick search. Thats how I found out about the water separator.
Well....I climbed under the truck and pulled the drain plug. I took the o-ring off and cleaned it up a little for the pictures...look at all of that metal loss.
WTF??? Has anyone else had this happen?
Here are some pictures of the filler neck:
And this is what I got out of my fuel/water separator...notice the rusty water in the fuel, and the debris floating around in there.
I am at a loss...what do I need to do???
2012 F-250 6.7L Lariat
4" BDS Suspension w/ FOX Shocks
20x9 BMF Rehab's, Toyo Open Country M/T's
2006 F-250 6.0L King Ranch
6" Pro-Comp Triple-X, Reservoir Shocks, Track Bars, Mazzi Hulks w/ Toyo Open Country M/T's, Airraid Intake, 4" S.S. Exhaust, SCT, CFM+, Xenon Headlight Conversion, Head Studs, Sinister EGR Delete, Westin Bull Bar
jconway is offline
post #2 of 6 Old 03-19-2010, 09:24 PM
Wow that has to be the worst one I have seen. Do not put that stuff in the tank to push the water through. You will be buying injectors for sure. I would drop the tank. Clean out the tank and lines. Then replace the fuel filters. That would be a start.
04 F-550 CC 6.0 4x4 cab n chassis 4.88 XLT 193K
Money maker with utility bed.
97 F-350 CC 7.3 ZF-5 4x4 4.10 324K
Moves my stuff around.
Hardline is offline
post #3 of 6 Old 03-19-2010, 09:33 PM
zgerm01's Avatar
Wow, my light has been on and off as of lately. I replaced both filters and drained some fuel but no change. My next step is to pull off my sensor and check that. The drain plug is seeming to strip out by using a 6mm hex, so i just pulled the entire plate off before. I heard the sensors corrode often and need to be cleaned/replaced. Good luck getting this all cleaned up and working good again.
2003 F-250 Crew Cab 6.0
Edge Insight CS, SCT XCal2 tuned by IDP, FCDP EGR delete kit w/ up-pipe, 4" MBRP Turbo-back exhaust, cat-delete, 6" Suspension Lift w/ 37" Toyo M/T's on BMF Novocane 20x10's, zoodad Mod. More to come...
zgerm01 is offline
post #4 of 6 Old 03-20-2010, 03:08 AM
Dr. of Linemantology
quequeg37's Avatar
It may be a little costly, but I would drop that tank and not use it back. If you love having your motor running i would get a new one or a good used one. As fr as diesel treatment, its not for anything like that. I've used power service treatment in my truck every tank since new and CETANE every other. Makes a huge dfferece. I also change my fuel filter, seperator fliter every 5k miles religiously. That orange stuff in your pic is water and thats what corroded your plug. I know at least 5 friends that were told by Ford that a defective batch of tanks had come out that rusted and grew mold. I thought it was pre 6.0 era though. good luck
[/SIGPIC]2004 F-350 Super Duty 4-DR./ 4X4 / Long Wheel Base/ FX-4 Package / Dulley / 4.10 Geared / 77,000 mi. / Lariat / Leather int./SCT Livewire Custom Tuned/ Cat & Muffler Deleted/custom EGR delete/arp head studs/black onyx head gaskets/stage 2 injectors/fauss fuel system/5" MBRP turbo back and exhaust/ all done by Russ Kennell at MAXIMUM DIESEL in San Jacinto, CA. scratch the Black Onyx gaskets. 5k later im back with the OEMs.
quequeg37 is offline
post #5 of 6 Old 03-20-2010, 03:32 AM
Mike Hickman's Avatar
I'D GET A NEW TANK PLUS FILLER NECK .WOW
TRUCK WAS STOLEN NOW IS SOLD 2006 Lariat FX4 F-350
7" BDS Lift
SCT Xcal3 Tuned By Truck Source Diesel TSD with SPD !
Triple pod Auto Meters
4" MBRP Exhaust
Straight piped Turbo back
Zoodad Mod
325/65/18 13.50's MTZ
18x10 Mickey Thompson Bead Locks
A1 H11 Studs Head Bolts/Studded
EGR Deleted
Harley HeadLights
S&B Intake
Mike Hickman is offline
post #6 of 6 Old 03-21-2010, 08:20 AM Thread Starter
jconway's Avatar
My first step will be to change the fuel filters again in 1000 miles. See how they look at that point.
quequeg37...I do love having my motor running!
If I still have a issues in 1000 I am going to drop the tank...never done this before, so I really don't know what I am getting myself into.
jconway is offline
