link error? - Ford Powerstroke Diesel Forum
post #1 of 6 Old 03-11-2010, 12:59 PM Thread Starter
I eat catfish's Avatar
link error?
I got in my truck today from leaving Lowes and the check engine light came on when I crunk the truck up. I drove home about 20 miles and everything was running fine. Stopped by Autozone to get them to pull the code and all the guy said was it showed link error, no codes. he said to check my fuses and see if one had blown that could cause the link error to show. Just finished checking every fuse I could find and nothing is blown. I unhooked the batteries to let the system reset and see if it was a valid error or something.
Anyway, how long should I leave them unhooked to make sure it's reset?
06 FX4 lariat Swamp's 58volt FICM...more to come!
I eat catfish is offline
post #2 of 6 Old 03-12-2010, 09:25 AM
Dr. of Linemantology
quequeg37's Avatar
i don't think unhooking your batteries is a good idea at all. Your PCM holds diagnostic codes it it fom the self test your truck does at each start-up. if you disconnect the batteries you also clear the memory of the PCM which holds historical diagnostic codes. Those code readers used at auto parts houses are junk and sould not be trusted. Find someone that has a proper scanner or for $100 bucks take it to Ford and let them put it on a scanner and havethe ability to read live data.
[/SIGPIC]2004 F-350 Super Duty 4-DR./ 4X4 / Long Wheel Base/ FX-4 Package / Dulley / 4.10 Geared / 77,000 mi. / Lariat / Leather int./SCT Livewire Custom Tuned/ Cat & Muffler Deleted/custom EGR delete/arp head studs/black onyx head gaskets/stage 2 injectors/fauss fuel system/5" MBRP turbo back and exhaust/ all done by Russ Kennell at MAXIMUM DIESEL in San Jacinto, CA. scratch the Black Onyx gaskets. 5k later im back with the OEMs.
quequeg37 is offline
post #3 of 6 Old 03-13-2010, 06:47 PM
Feedback Score: -1 reviews
need to have it scanned at the dealer or a repair facility. may be something simple, but need to start with codes before we can help
fordmasterdieseltech is offline
post #4 of 6 Old 03-14-2010, 04:26 AM Thread Starter
Sorry I didn't come back sooner, but I hooked the batteries back up after about 30 min. and the light quit and it's been running like a champ since.
post #5 of 6 Old 03-14-2010, 04:51 AM
FJuanfiddy mod
Dave's Avatar
Quoted: 10 Post(s)
The autozone scanners dont read diesel codes
Email:
2006 F250 ECSB Lariat 4x4
Edge Insight CTS
Coolant filter
Dave is offline
post #6 of 6 Old 03-16-2010, 04:54 AM Thread Starter
popped up again yesterday. Advance Auto's reader said Cylinder #2 glowplug. just had all 8 replaced in Jan.
