Headgasket Question for the tech's - Ford Powerstroke Diesel Forum
Old 03-10-2010, 07:50 AM
when you remove the headgaskets do you need to remove the injectors prior to head removal?
Old 03-10-2010, 08:18 AM
Yes, the injectors protrude into the combustion chamber, you could damage them easily
Old 03-10-2010, 08:25 AM
<-Day Of Fail now SOLD
It also helps to remove the glow plugs so you don't damage them if you put the head on a bench.
Old 03-10-2010, 09:43 AM
Hey guy's thanks , My truck was in the shop 6000 miles ago they said that they just lifted the heads and put new gaskets in and did not remove the injectors and now it is in there rite now they are saying all my injectors are leaking filling my crank case up with diesel . Diag on it with a die test valve covers off
