First Post-Cold Start Problem - Ford Powerstroke Diesel Forum
post #1 of 4 Old 03-09-2010, 07:34 PM Thread Starter
Hello all and thanks for helping this is a great forum!
So here is what is happening; tried to start the truck (6.0) and it wouldnít fire up. It took about fifteen tries before it started. Some black smoke on the third attempt and then finally it kicked over but didnít run. Several more tries with the same result and then it finally started up and ran a little ruff for a min or two.
The truck has 89,000 miles and sports a Banks six gun tuner, K&N intake, and Banks exhaust. These are the only changes that I have made to the truck. I run Motorcraft filters and oils and have maintained regular service intervals.
The temp here dips to about twenty degrees at night. I am defiantly not engine savvy at all, but I am learning. I havenít had the dealer plug into the truck yet for codes; I would like to try and fix this myself if possible (trying to save money). Any help that could be offered would be great and thanks again.
Alex
Montana F-350 is offline
post #2 of 4 Old 03-09-2010, 08:06 PM
if the check engine light isnt on it probably wont have any codes....if so they will be all in the history.....i assume your plugging the truck in at night and utilizing the block heater???
2005 PSD xlt fx4 6.0 (extended cab short bed)
mods:
zoodad mod
sct livewire custom tunes by TWISTED DEISEL
autometer boost, pyro and trans temp gauges
3.5" down pipe, 4" mbrp straight piped stack
AFE stage 2 intake
CFM largemouth intake manifold and intercooler pipe
12k HID's
future mods:
RCD egr delete, ARP studs & black onyx head gaskets (TWISTED DIESEL), CCV mod
chris_the_stroker is offline
post #3 of 4 Old 03-09-2010, 08:14 PM Thread Starter
Actually, on this particular morning I had forgot to plug in the truck the night before. I usually do plug it in. No dash light or warnings either. In addition; after sitting for eight hours while i am working. I have noticed that the time that it takes to start seems to be longer and recently takes more than one try to start. During this period of time of course it is not plugged in.
Last edited by Montana F-350; 03-09-2010 at 08:27 PM. Reason: addition to original
post #4 of 4 Old 03-11-2010, 08:22 AM
bryceba's Avatar
I am interested in others thoughts as I am having a very similar problem
2001 F250 CC SB
5 In exhaust made by me
DP-Tuner 80 tow, 80 econ, 140 aggressive SWEEETTT
Boost Controller
AFE Intake
Leveling Kit w/ 35x12x16
Projector Headlights
New MB Wheels
bryceba is offline
