Powersteering/brake whine. - Ford Powerstroke Diesel Forum
Old 03-08-2010, 03:44 PM
Question Powersteering/brake whine.
Well, I had the powersteering gear box replaced just over a year ago so ofcourse it is not covered anymore. Anyhow, when I turn at low speeds, the powersteering whines and the wheel stiffins up a bit. When I press the break pedal, I can feel it in the breaks, the whine also gets louder when I hit the break pedal.
Any ideas?
Fluid is full.
Old 03-08-2010, 05:01 PM
Feedback Score: -1 reviews
sounds like a worn or weak p/s pump. do its get better if you raise the rpm?
Old 03-08-2010, 05:04 PM
I wanna go fast!!!
I have the exact same problem with mine too...
Old 03-08-2010, 08:06 PM
Yes, it seems to go away at higher RPMs. It just growls when I steer, or floor the brake pedal.
Old 03-09-2010, 10:31 AM
I am thinking power steering pump?
When the RPMs go up, it goes away.
When I am sitting still, I can turn the wheel and it wheel whine and is hard to turn, but when I rev it up, everything clears up.
