where is the coolant coming from? - Ford Powerstroke Diesel Forum
Old 03-07-2010, 10:42 AM
so my truck hasnt been run since friday, and when i went outside this afternoon, there was a big puddle of coolant/water under the front of the truck. so i popped the hood and the first place i see water is under the egr cooler... think its bad or is the little rubber hose on it leaking?
Old 03-07-2010, 07:19 PM
Powerstroke Techie
It's the rubber hose leaking. This is a very common, but easy to fix problem.
Old 03-08-2010, 12:41 PM
Feedback Score: -1 reviews
Agree, common for the hose to leak, replace with the updated blue hose.
Old 03-09-2010, 01:40 PM
Now tell us where to get just the hose?My local dealer say I have to buy either an intake gasket kit or a new egr to get the hose.
Old 03-09-2010, 01:45 PM
Powerstroke Techie
I call BS. Go back to the dealer and ask for part number RH-153.
Old 03-09-2010, 02:00 PM
im just gonna do the delete while i have the turbo and everything else off...
Matt
Old 03-09-2010, 02:28 PM
Powerstroke Techie
Matt
You don't need to remove the turbo to replace that hose.
Old 03-09-2010, 04:17 PM
oh i didnt know that. well ive already ordered the parts so i think im just gonna go ahead with it. it needs to be done anyway.
Old 03-19-2010, 07:37 PM
my 04 is leaking from the egr cooler hose. how are you able to change it out without taking off the turbo? looks impossible.
Old 03-21-2010, 03:51 PM
Remove the two t-30 torx bolts from the oil cooler adapter/top plate, seperate the two halfs and pull the top plate with the hose still connected. This use to be a very sweet warranty repair until ford found out how we were doing it. If you are in the SW Fl area I would be more then happy to help/do it for you.
