batteries? alternator? what? - Ford Powerstroke Diesel Forum
post #1 of 12 Old 04-14-2007, 12:07 AM Thread Starter
Heres whats goin on with the truck. its an 03 6.0 powerstroke. the last month or so my stereo has been flickering on and off a lot and the subwoofers rarely work. At night the headlights flicker pretty intensly. I got the batteries check out at oreilly, one was bad, so i changed it. I got one with 875 CCA instead of 750. I thought the problem was taken care of! Now the stereo, subs, and headlights still do the same thing but now the guage cluster has joined the fun and will drop as if the truck is off...then go all the way up for a few seconds...then drop all the way off again....then go back to normal. Also, the battery light flickers on and off just barely. I had replaced the alternator maybe a month or two ago. What the heck should I do next!?
kwebster1 is offline
post #2 of 12 Old 04-14-2007, 12:28 AM
HardLuck Case of the Year
Ditty's Avatar
Send a message via AIM to Ditty Send a message via Yahoo to Ditty
Did you get the ALT from the dealer? Sometimes you can get a 'bad' ALT from places like Advanced Auto and Napa. Your best bet is to get a direct replacement from the dealer. Yeah, your going to pay a little more, but your not getting a rebuild, your getting an all new one!
DITTY
Brisco:-White 2000 F-350 PSD CrewCab/SRW/LongBed/4x4/6spd Manual/HUGE Powerstroke.Org Vinals!
Favorite Mods: Baby-seat mod/Girlfriend delete/6pos on Xtreme!
Repairs since bought: both batteries/alternator/3 transmissions/4 clutches/entire front axle/new steering stabilizer/power steering pump
Still broken: cracked windshield/all glowplugs/glowplug relay/4WD still out/trailer harness no power
Current Best: 16.149@84.13MPH (Est.7800lbs)
Ditty is offline
post #3 of 12 Old 04-14-2007, 12:55 AM Thread Starter
nope i bought it from oreilly. so would that be everyones best guess? try another alternator? Ill check on pricing for one from the dealer tomorrow. Could it also have been that i made that alternator go bad bc it was put under so much immediate stress form having a bad battery?
post #4 of 12 Old 04-14-2007, 01:00 AM
Ditty's Avatar
Could be. But it sounds like a defective ALT.
DITTY
Ditty is offline
post #5 of 12 Old 04-14-2007, 07:11 AM Thread Starter
ok im changing the alternator today!
post #6 of 12 Old 04-14-2007, 07:56 AM
The Fat Mod
Logan's Avatar
If you got it from Oreilly's, they should have a lifetime warrenty on it. Take it back and get them to trade it out for a new one. Also, how big of a system do you have? You have to have a pretty big system or a WHOLE bunch of other stuff running to kill one of these alternators. One more thing, how many miles on your truck?
Logan is offline
post #7 of 12 Old 04-14-2007, 08:16 AM
ADMIN AND TECH
SCUFFY828's Avatar
i believe id get them to check or swap you out alternator if you want to , i may be wrong but it sounds like you also might have a bad ground follow both battery ground leads , there was a recall on the negative post on right front corner of block due to it coming loose on certqain models ,but all could do that , believe i would look there
ITS STOCK
SCUFFY828 is offline
post #8 of 12 Old 04-14-2007, 10:00 PM Thread Starter
i run my laptop, 2 12in subs (nothin major) and an overhead dvd player and in dash dvd player. The truck has 86,000 miles on it. I tlaked to oreilly and there is a lifetime warranty on it so im getting it swapped for free! ill let yall know if it works out when its all said and done.
post #9 of 12 Old 07-21-2007, 05:07 AM
it's the alternator. i had the same problem, changed both batteries, then had the alternator rebuilt, then rebuilt again, then i have to take it off again because it happened again last night. this is all within the last 9 months and less than 5,000 miles. Ford HAD to know these were going to be a problem because they made the alternator WAY TOO easy to take off. I will also be intalling a voltage gauge in the truck soon.
87mustang is offline
post #10 of 12 Old 07-21-2007, 05:35 AM
SgtStroked7.3's Avatar
Send a message via Yahoo to SgtStroked7.3
flickering gauges and headlights doesnt sound like an alternator though. if it were the alternator, the stuff would dim out not just turn off like a lightswitch. i would try the ground idea or check any other wiring that runs from the batteries and fuses. something must be loose. good luck and keep us posted.
EDIT: if it was the alternator, woudlnt the truck die too becasue the HEUI injectors would fail due to them not getting any voltage.....?
2001 F250 SuperDuty 7.3
AutoMeter Gauges, 5" Turbo Back Exhaust, aFe Stage II Intake, XCal 2 With Tadds Tunes,
2" Leveling Lift, Custom Built Transmission, AIH Boost Fitting.
Snow Performance Water/Methanol Injection Coming Soon...
"When the rich wage war, It's the poor that die"
-Unknown
SgtStroked7.3 is offline
