motor missing when cold 6.0 - Ford Powerstroke Diesel Forum
post #1 of 8 Old 01-16-2010, 04:33 PM Thread Starter
Smile motor missing when cold 6.0
When i start my 03 6.0 when it is cold it misses until it warms up. It has no power until it warms up. The other day I was going down the road and it just started slowing down and it finally stopped running. I took it to a mechanic an he said the high pressure oil pump was bad so he replaced it. It would start up but did not have the power it should. Can anybody help me. Thanks
regman154 is offline
post #2 of 8 Old 01-16-2010, 04:38 PM
jesilvas's Avatar
Quoted: 3 Post(s)
He probably just threw it out there just to get money. 6.0s have this problem a lot I've noticed. Do some searching and digging. You should find it.
4R100, 2wd
330,000 + miles
jesilvas is offline
post #3 of 8 Old 01-16-2010, 04:56 PM
Big Heat's owner's Avatar
yeah, i got an 03 6.0 too. same stuff. try this, let it warm up before you drive it. no choking, all power. its a cold trbo, tranny and diesel engine. it needs heat my man!!!
Big Heat's owner is offline
post #4 of 8 Old 01-16-2010, 06:13 PM
Powerstroke Techie
FICM failing or some injectors are varnished up internally, would be my guess. What weight oil is in your truck, and what is the ambient temperature there? What do you consider 'cold'?
Ford Senior Diesel Technician
2008 F-350 4x4 Off Road 6.4 Powerstroke Diesel
There are strange things done 'neath the midnight sun by the men who moil for gold.
The arctic trails have their secret tales that would make your blood run cold.
Big Angry Hillbilly is offline
post #5 of 8 Old 01-17-2010, 12:45 PM Thread Starter
Why does the check engine light not come on. If it is missing or no power. Thanks
post #6 of 8 Old 01-17-2010, 01:07 PM
BLACK_PSTROKE's Avatar
like big heat said its just cold. you gotta let a diesel warm up or it will run like chit! especially a 6.0 or 7.3 psd.. also what are you calling cold??
09 F250 FX4
2n006 F-350 fx4 lariat
cc. 6 sp. man. SOLD..........
MEMBER $5.00 gallon club
NRA member
BLACK_PSTROKE is offline
post #7 of 8 Old 03-15-2011, 04:23 PM
It's really a good thing to replace oil pump but I think you should focus more on the battery and alternator. It will be a good idea to run parasitic test.
__________________________________________________ ________________
cheap car part.com
reinaldo is offline
post #8 of 8 Old 03-15-2011, 04:40 PM
Powerstroke Techie
forddieseldoctor's Avatar
You are supposed to be able to take off cold without it running like crap. It's not recommended, but it's supposed to be able to do it. I agree with BigAngryHillbilly that it sounds like a ficm issue.
Ford Senior Master Diesel Tech
IF YOU DON'T WANNA STAND BEHIND OUR TROOPS
THEN FEEL FREE TO STAND IN FRONT OF THEM
Meet Double Aught
2000 F250
forddieseldoctor is offline
