2005 F250 6.0 "PROBLEM" - Ford Powerstroke Diesel Forum
post #1 of 6 Old 12-07-2009, 06:26 PM Thread Starter
Here is my situation. Last night I flushed and replace my coolant in my 6.0 45k on it. This morning I get in it and crank it up. Runs great. It is 20 degrees by the way. Ayway no rough idle or anything. Let it warm up about 1 min and I take off slowly and notice alot of whiteish blue smoke blowing out of the exhaust. I pull over and look at it idleing and still blows the smoke out. I start driving it and when it warms up it goes away. About 5 min. Let it cool a little and the start it up and the smoke comes back for a a couple of minutes. The smoke does not smell like coolant but unburnt fuel. Someone said that possibly it could be the thermostat stuck open not letting it warm up correctly thus not burning the fuel. Anyone have this problem or any info greatly appreciated. Thanks,Eric
Powerhouse9228 is offline
post #2 of 6 Old 12-07-2009, 11:06 PM
444 ci's Avatar
my buddys truck does the same thing its an 05 6.0 im thinking a sticky injector but hopefully someone will chime in here with the real answer.
444 ci is offline
post #3 of 6 Old 12-08-2009, 12:47 PM
Goose350's Avatar
If it smells like fuel its a stuck injector(s)
The Mullet Mod
Stock 2005 F-350 4x4
*Afe Intake
*4" TB Exhaust
*Scangauge
*SCT
oil bypass
water pump
*Tuned FICM
Goose350 is offline
post #4 of 6 Old 12-08-2009, 01:03 PM Thread Starter
Yea I would say it smelled like fuel. Took into Ford today and the tech just thought the injectors weren't calibrated right. So he gave me the brand new flash and check out my vitals. All was good. Hopefully it fixes the little problem. Was thinking also, I gutted my cat and that might be just the normal smoke that the cat would of burnt up "if it was there" lol. It is about 20 degrees here. So the injectors will run a little rich anyway, I think. Anyway something to think about. Thanks for the replys and I will let you know if it clears up the smoking problem.Eric
post #5 of 6 Old 12-12-2009, 08:09 AM
KYmxracer52's Avatar
I had a similar problem last week, and by the weekend, the truck wouldn't even start when cold. Took it to the dealer this past Tuesday and just got it back yesterday (Friday). Ended up having to replace the FICM and install 2 new batteries. He said it had the injectors all out of time or something like that. We'll see how it does now.
2005 F-250 CC SB-SCT,Edge Insight,5" MBRP, 5" ProComp lift, dual-stabilizers, 35x12.50 Federal Couragia MT, 20x10 Fuel Hostages, B&W ball, Truxedo roll cover
KYmxracer52 is offline
post #6 of 6 Old 12-12-2009, 06:12 PM Thread Starter
Well it was a little warmer today about 30 and the truck ran great. No smoke or anything. I really think it was from letting my truck idle for about 15 minutes when it was 5 degrees and then I just had to go about 5 miles and it didn't let it warm up. Took out the egr and it had a little oil on it. I also think it is the ccv as well. So I am going to bypass that. I am going to check my voltage on my ficm tomorrow if it isn't raining. So here is the combination of things such as 1. Not letting it warm up. 2. Rich fuel 3. Oil additive. 4. 2 stroke oil 5. ccv 6. cold weather with no cat or muffler. We will find out if this is the problem. Thanks to all for in input. Eric
