Go Back   Ford Powerstroke Diesel Forum > Ford 03-07 6.0L Powerstroke Forums > 6.0L Problems Forum
Old 11-06-2009, 01:39 PM
mbahr22250 mbahr22250 is offline
Exhaust hitting cab
Installed a Magnaflow turbo back exhaust on my 06 6.0 about two months ago and no matter how much I mess with it I can't get it away from the cab. It's rattling inside and driving me crazy! It's hitting right above where the firewall, transmission tunnel, and floor all come together. I took the pinch weld and bent it out of the way and rounded it off and repainted it but I guess it wasn't hitting there. I'm getting pretty frustrated.
Old 11-06-2009, 07:12 PM
dustindiesel dustindiesel is offline
u just have to keep adjusting it,try taking it loose at the turbo and twist it a little..mine did it too
Old 11-07-2009, 04:30 AM
I tried that. It seems like no matter how much I tighten the v-clamp on the turbo, it always moves back. I was thinking of ordering a roll of header wrap from Jegs and wraping the downpipe from the turbo down to the first bend.
Old 11-07-2009, 05:22 AM
kinghawg98 kinghawg98 is offline
Mine will hit on the trans crossmember, but doesnt look like it is hitting and makes a horrible sound.
i have to kick it out of the way once a month. One day when I have access to a welder I'll weld it in place.
Old 11-07-2009, 10:37 AM
That's the way mine is. When I crawl under there it really doesn't look like it's hitting but I know it is because I can hear it.
Old 11-16-2009, 08:54 PM
jensenrcng jensenrcng is offline
does your dash rattle and do you feel the shake in your feet? mine does it but only some of the time.
