Go Back   Ford Powerstroke Diesel Forum > Ford 03-07 6.0L Powerstroke Forums > 6.0L Problems Forum
  #11 (permalink)
Old 11-04-2009, 01:01 PM
tmanscrew tmanscrew is offline
Just talked to a Ford Diesel Master Tech with 20 yrs. exp on diesels and he said it is a turbo CHRA problem. Basically the seals on the turbo shaft are allowing oil to get by and that is what is causing the smoke. I tried to steer him away from his diagnosis, but he held his guns and said he had no doubt that it is a turbo issue. Guess I will just keep taking it back to the *&%^%&*ship until they get it fixed!
  #12 (permalink)
Old 11-04-2009, 04:14 PM
fiveton fiveton is offline
So Let me get this straight by me changing my filters all of a sudden my turbo's going bad. It's got to be something simpler then that.
  #13 (permalink)
Old 11-05-2009, 06:59 AM
No, I didn't say that. I said that it appears my problem is oil getting by the o-rings in the turbo. I don't think changing my fuel filters had anything to do with this. In fact, I don't know what causes this, but I don't think it is fuel filters. I just described my problem to him and he told me that when you are seeing blue smoke like I am, 99% of the time it is coming from the turbo. Your problem may be different from mine. Either way, I don't think changing the fuel filters had any thing to do with it. I am just hung up on how to convince the dealership to check this. I know now that I was just put off the other day. Sure, my EGR valve was prolly clogged up, but a bad EGR valve does not cause blue smoke, I know that now, so I am learning both about the truck and about dealerships. They see my truck is under warranty so they slap a new EGR valve on that takes about five minutes and they get paid by Ford for doing the work and tell me it should get better in a few days, knowing the whole time its not. At least I hope they didn't think that was going to fix the blue smokle problem. Anyway, they will get a chance to fix it again next week as I will be taking it back and maybe I can convince them to check the turbo!
  #14 (permalink)
Old 11-06-2009, 04:04 AM
Originally Posted by fiveton View Post
I think I narrowed it down to the cause of the blue smoke. I put diesel kleen in it right after I changed my filters, never used diesel kleen before that, now wham I have blue smoke coming out of both tail pipes. I have used RBP additive before that and never had blue smoke . I won't be using that additive again I thank you.
The only easy day was yesterday
  #15 (permalink)
Old 11-09-2009, 08:17 AM
ARN1040 ARN1040 is offline
Fiveton-which diesel kleen additive did you use? The silver bottle or the white? I had been having a very similar problem but I had over looked that I switched from the silver bottle to the white because we were getting colder weather.
  #16 (permalink)
Old 11-09-2009, 11:44 AM
I think I tried the white bottle for the first time.
Fiveton
  #17 (permalink)
Old 11-09-2009, 11:49 AM
Hmmm, maybe an oil change, fuel filters, and an additive switch and I'll see what happens. I have my doubts it'll do much but why not.
  #18 (permalink)
Old 11-10-2009, 03:05 PM
RanchStroke RanchStroke is offline
I just got a call from the dealership and I had the same problem. They replaced my FICM. I will see thursday if it fixed the problem.
  #19 (permalink)
Old 11-10-2009, 05:56 PM
I just switched to Valvoline 5w-40 synthetic...only drove it home so not sure what I think of it yet. My truck sure does have a slight haze to it while idling but I'll give it some time. I was running 15w-40 FMC dino oil so I'm thinking I should change the filter after 500-1000 miles incase anything was worked loose. I ordered some of Hot Shot's Secret so I will have to figure out when to put that in.
  #20 (permalink)
Old 11-11-2009, 12:33 AM
mwillmot mwillmot is offline
I have the 7.3 and I have the exact problem. As soon as the truck idles for more than 20 seconds small clouds of blue form. I would like to fix this also, so any info would be appreiciated.
Cheers Mark
