Go Back   Ford Powerstroke Diesel Forum > Ford 03-07 6.0L Powerstroke Forums > 6.0L Problems Forum
Old 10-28-2009, 03:01 PM
StrokerAce06 StrokerAce06 is offline
Question Lost power/White smoke
I was just driving down the highway going 55 when all of a sudden my truck lost power and was billowing white smoke from the exhaust. Smell of raw fuel, runs rough...real ruff, can't move it over a few inches then she just dies. Any ideas? Oil taste like oil and coolant isnt burning. I do have blow by out of the oil fill though. 06 psd
Old 11-04-2009, 06:46 AM
No one has any idea?
Old 11-04-2009, 07:11 AM
Abrannan19 Abrannan19 is offline
injector issue, a small amount of blow by is normal, if its enough when you put your hand over it it pushed your hand up there is an issue. Typical problem is an injector cup loosening up and allowing combustion to get past the injector, this will cause blow by and white smoke out the exhaust that smells like fuel.
Old 11-04-2009, 09:01 AM
My brother just put it on his computer and it set a EGR code...
Old 11-07-2009, 09:37 AM
So I had my truck in the shop.....needed batteries. I have never heard that if your batteries are low on voltage it will F with the computer. I figured I woulda seen a low battery dummie light or somthing. New batteries and she runs like a champ!
Old 11-13-2009, 11:33 AM
axiom axiom is offline
you check the grounds before you condemned the batteries ?
