Go Back   Ford Powerstroke Diesel Forum > Ford 03-07 6.0L Powerstroke Forums > 6.0L Problems Forum
Old 10-22-2009, 01:45 PM
bevo0611 bevo0611 is offline
2006 6.0 won't start after warm
Let me give you a quick background on the work thats been done. The egr cooler went bad causing the heads to get warped. We had the heads milled and put in a new egr valve (wanting to do full egr deletes on all 5 but needing to wait until after harvest). After we got it all put back together it started right up, but when you run it for a while and kill it it won't start back up until it cools down. Does anybody know what could be causing this?
Old 10-22-2009, 01:57 PM
kingranch89 kingranch89 is offline
Mine acted like that when my HPOP went bad an i have a 07 6.0
Old 10-22-2009, 02:06 PM
cowboyf250 cowboyf250 is offline
icp sensor?
Old 10-22-2009, 04:16 PM
Socal-powerstroke Socal-powerstroke is offline
sounds like a high pressure oil leak...
Old 10-22-2009, 04:19 PM
Robsr Robsr is offline
Can you get hold of a scan tool? need to check injection control pressure, and about eleven or so other miraculous events that need to take place all at the same time in order for it to start, lol
