Go Back   Ford Powerstroke Diesel Forum > Ford 03-07 6.0L Powerstroke Forums > 6.0L Problems Forum
Old 10-17-2009, 09:25 AM
outrage outrage is offline
Unhappy HELP removing Dp from turbo
How do I remove down pipe from turbo? I loosened the clamp bolt but it didn't seem to release. I'm really not sure how it's connected or how it looks under the clamp. Any advise please. Thx in advance.......Terry
Old 10-17-2009, 09:39 AM
1995psd 1995psd is offline
idk bout the 6.0's but i have heard a few times you should let the clamp soak in some penatrating oil like pb blaster for a good little while. i didnt have to with mine, i just smacked it rite good with a hammer and chisel and it broke lose but mine is a 95" and yours is a 04 so it mite be a different clamp
good luck anyways
Old 10-17-2009, 09:57 AM
Thx 1995psd I going to try and hit it a couple times maybe it will jar it loose. Thx again......Terry
Old 10-20-2009, 11:43 AM
guntersxr guntersxr is offline
take the clamp off completely, on some dp's they have a little "hook" that folds over that you just have to lift.
