Go Back   Ford Powerstroke Diesel Forum > Ford 03-07 6.0L Powerstroke Forums > 6.0L Problems Forum
  #11 (permalink)
Old 10-20-2009, 04:51 PM
SWGent SWGent is offline
I had this start happening on my f 250, 06 model 2 weeks ago. Very faint odor, at idle mostly, and no obvious leaks. Drives me nuts! no problems till now...116,000 miles so hope theres an answer somewhere. Thanks for pitchin' in on this question guys.
  #12 (permalink)
Old 10-20-2009, 06:36 PM
GS247 GS247 is offline
Originally Posted by amievil844 View Post
Workin on it. Stop by ford parts counter today and they will have one for me tommorrow. Thanks for the pdf.
no problem.
SWGent
check the side of your fuel filter housing on top of the engine. There is a key hole shaped seal that is leaking on ours. its where one of the lines goes in or out (not sure what direction it flows).
  #13 (permalink)
Old 10-20-2009, 06:38 PM
i have a PDF file of the parts diagram from Ford but i dont know how to post it here. if you pm me i will send it to you.
  #14 (permalink)
Old 11-09-2009, 05:56 PM
found a small leak on back of cap on filter housing. Tried to loosen it to check it out, with 1/2 inch drive ratchet...cracked entire top out! Ford said $65.00 and have to order...got out the JB weld and the brake cleaner. Took 3 tries but it's stopped for now...
Thanks Gentlemen.
  #15 (permalink)
Old 11-12-2009, 03:03 PM
Keviny707 Keviny707 is offline
Same issue on a 05 F250. Diesel smell in cab when A/C is on at idle. Ford service manager said they didn't smell anything. I was there with the manager telling him there's fuel vapors coming through the vents...He just looked at me and said "I don't smell it." How do you deal with that? Anybody I've ever pointed it out to can smell it. Sometimes passengers comment on it.
  #16 (permalink)
Old 11-12-2009, 06:55 PM
did you check the side of the fuel bowl like stated above. PM me your e-mail and i will send you a PDF file where most of ours are leaking from.
