Just had the turbo cleaned, I removed the EBP tube and sensor and it was as clean as one right out of the box! Shouldn't there be some soot buildup in it????? KOEO EBP 14.62, At Idle EBP 17psi, MAF 4.45lb, MAP 15.22psi, BAR 14.68, VGT 65.22%. WOT EBP 46.70psi, MAF 26.46lb, MAP 37.12psi, BAR 14.68 VGT 37%. I used AE to get this info and don't know if the parameters are normal or not. At idle there is no whistling noise from the turbo, just a low tone drone sound off and on for a few seconds. It's not blowing any smoke. The only thing I can think of is a bad VGT solenoid. Any help would be awesome!!!lease:lease:
I did command it shut and it's functional but it could be failing. also I'm not positive my turbo was cleaned. I had the work done at a local shop and the guy was rushing to get all the work done to it last Friday in less than 8 hours. He did both stand pipes, STC upgrade, oil cooler, EGR delete with down pipe, oil filter stand pipe and he was done with it at 4Pm. I would have done everything myself but I'm paralyzed after rolling my 99 F250 14 years ago!
I don't think it was taken apart with all the work he did to your truck in an 8 hr. day. If you were charged for it I think he owes it to you to do the job.
Related Threads
Ford Powerstroke Diesel Forum
5.4M posts
265.8K members
Since 2005
