Go Back   Ford Powerstroke Diesel Forum > Ford 03-07 6.0L Powerstroke Forums > 6.0L Problems Forum
Old 02-21-2007, 02:53 PM
6POINTO 6POINTO is offline
Engine will not start
I did a 6.0 swap into a 2000 Superduty. I swapped the entire dash, and harness. Everything comes on with the key, but the engine.
A guy on another board suggested that I unplug the single wire male/female connector on the passenger side of the engine bay and jump the male side of the connector to see if the engine turns over. It runs when I do this, but I can not put it into gear and the accelerator pedal does not work.
What might be the problem?
Thanks
Old 02-21-2007, 02:58 PM
Jon Jon is offline
DO YOU KNOW WHO I AM?
Wow
This is really interesting! I will have to think. I have to give you credit on this.
Old 02-21-2007, 03:02 PM
thanks. I am probably just a few minutes away from being done with this project. If I could figure out what is going on.
Old 02-21-2007, 03:05 PM
bigcountrysg bigcountrysg is offline
Countryboy Mechanic
You got kahoneus or how ever you spell it. To do a 7.3L swap out to a 6.0L why did you decide to do this swap if you don't mind me asking.
I am curious did you swap out the PCM for the new 6.0L
Old 02-21-2007, 03:10 PM
ABOBB ABOBB is offline
Just call me DOC!!!
Wow.. that is a very interesting swap... It sounds like you did things right, and were very thorough about it. I'm sure you will find your gremlin soon.
When you get some time... let's see some pics.
Old 02-21-2007, 03:16 PM
7.3 was getting ready for a rebuild, and had a buddy that rolled his truck. I swapped EVERYTHING. It was alot of work. I'll post some pics when I get it running.
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
