Go Back   Ford Powerstroke Diesel Forum > Ford 03-07 6.0L Powerstroke Forums > 6.0L Problems Forum
Old 08-23-2009, 05:51 PM
CCSBD CCSBD is offline
Tryin to figure this out?? Please help! (VID)
The batteries are not dead and are putting off the right voltage. I checked all the fuses under the dash. I dont know what else to check? Can anyone help please.
Old 08-23-2009, 05:54 PM
TurboSevenThree TurboSevenThree is offline
I miss the 90's. =[
Clean and tighten up your battery cable connections. That's EXACTLY what happened to me. Everything on these trucks is meant to run on at least 9v, when it's below that all the relays click and things go hay wire. Mine got real corroded and a bit loose. Try that, it's free. I bought a battery post/cable brush, worked great.
Old 08-23-2009, 05:59 PM
dhanna6powerstroke dhanna6powerstroke is offline
Got Smoke?
You've got a ground issue. Did they have the cab off when the studs were done?
Old 08-23-2009, 06:03 PM
Yes they lifted the cab. You mean like a ground strap or something? Anyone know where all the ground straps are? I will try and clean the battery posts to cause they are coroded
Old 08-23-2009, 06:08 PM
Got Smoke?
That's what is wrong. When they reinstalled the cab, the didn't get all of the ground straps/cables hooked up.
Old 08-23-2009, 06:17 PM
03f250stroke 03f250stroke is offline
so all of a sudden you parked the truck and next time you tried to start it that happened?
you didnt mess with anything prior to starting it? install any electrical things?
Old 08-23-2009, 06:20 PM
chuckles chuckles is offline
Send a message via Yahoo to chuckles
yep, looks like a ground issue. There is one that connects engine to body at the passenger side firewall. Also on passenger side about mid cab on frame. There may be more, but these are two that I know of. Also check all the connections on driver side fender area directly behind the driver side battery. One of those connections could be loose.
Old 08-23-2009, 06:50 PM
I picked it up from the shop. It was a little sluggish to start then but just thought since it was unhooked for a week. Then i go home let it sit for about 2hrs then go to start and nothin. Got it to fire once and went to the store and some other places leaving it running the whole time to let it charge (thought it was batteries) then came home and went to start it that night and nothin and have not been able to start since. Did not do anything to electrical.
I checked the one mid frame and all the connectors behind driverside battery. The engine one to the battery is that low or high were it connects to the firewall?
Old 08-23-2009, 07:29 PM
its probably a connection like these guys say
on my truck though i had a similar problem but my odometer was showing "0000000" and it was my pcm
Old 08-23-2009, 07:59 PM
Damn grounding crap!! They should make one biga$$ strap and put it to the frame
