Go Back   Ford Powerstroke Diesel Forum > Ford 03-07 6.0L Powerstroke Forums > 6.0L Problems Forum
  #11 (permalink)
Old 08-23-2009, 08:01 PM
bockhold bockhold is offline
broke college kid
Send a message via AIM to bockhold Send a message via MSN to bockhold Send a message via Yahoo to bockhold
that is so weird.
  #12 (permalink)
Old 08-23-2009, 08:12 PM
chuckles chuckles is offline
Send a message via Yahoo to chuckles
Originally Posted by CCSBD View Post
I checked the one mid frame and all the connectors behind driverside battery. The engine one to the battery is that low or high were it connects to the firewall?
It's directly on the passenger side firewall above the evap housing. The strap goes from there to the rt rear cylinder head.
  #13 (permalink)
Old 08-23-2009, 08:31 PM
CCSBD CCSBD is offline
Ok looked at that strap and it doesnt go to above the evap housing it goes down and attaches below the cab? the right next to that there is a strap going from the cab to the frame
  #14 (permalink)
Old 08-23-2009, 08:57 PM
nccatfan nccatfan is offline
Send a message via AIM to nccatfan
I'd start at the batteries. I recently had an issue with mine. Went a few weeks with a sluggish/long crank before it fired up... one day I get to work, try to restart it, then everything went crazy! Could hear all my relays cycling and then nothing when I turned the key. Was getting 7.8V at the power outlet in the dash. Cleaned/wire brushed battery posts AND clamps (didn't even look that bad) till they were shiny again. Now it starts better than it ever did!
  #15 (permalink)
Old 08-24-2009, 05:43 AM
Well my mechanic guy called me today and said he thinks its the batteries cause they put a charger on one and a jump box on the other to get it started on Friday. He said he just forgot to tell me they did that so i am gonna try new batteries
Can bad batteries give out good voltage when just sitting there?? I bet there is a difference with a load on it vs just sitting there?
  #16 (permalink)
Old 08-24-2009, 07:16 AM
03f250stroke 03f250stroke is offline
yeah they give out "good/better" voltage with say a multimeter but when using a load tester it could drop to 6 volts.
i invested in a load tester and it has been great. multimeters are great for finding sources and stuff but i never use that to test my battery
  #17 (permalink)
Old 08-24-2009, 07:52 AM
TurboSevenThree TurboSevenThree is offline
I miss the 90's. =[
Yupyup.
  #18 (permalink)
Old 08-24-2009, 07:54 AM
I miss the 90's. =[
Technically anything under 12.6v is considered dead. And like I said the trucks are made for 9v or more, if everything receives less than that, your video will happen.
  #19 (permalink)
Old 08-24-2009, 03:26 PM
You should charge the batteries, take the to an auto parts place, and have them load tested.
  #20 (permalink)
Old 08-24-2009, 03:42 PM
BIGBILL105 45 BIGBILL105 45 is offline
I would def have the batteries tested before you buy new ones and also clean your battery cables.
