Go Back   Ford Powerstroke Diesel Forum > Ford 03-07 6.0L Powerstroke Forums > 6.0L Problems Forum
Old 08-22-2009, 08:34 PM
CCSBD CCSBD is offline
Batteries died after stud install??
Any idea what would have caused this?? You think they are just bad or something not hooked back up or thought about going and buying 2 new batteries but figured I would ask here first.
Old 08-23-2009, 07:01 AM
chuckles chuckles is offline
Send a message via Yahoo to chuckles
check for a draw, and make sure your alternator is putting out. You had the truck in a hundred pieces, it's easy to have left something loose.
Old 08-23-2009, 08:01 AM
ok batteries are reading good. when i open the door the bell sounds fine. turn the key backwards for the radio and it works fine. but when I turn the key forward the lights go nuts on the dash flickering and what not, door chime sounds like it wants to die. Whats wierd is that every once and awhile it will act fine glow plugs will charge and when I go to crank nothin? then the lights go hay wie again? Any ideas?
Old 08-23-2009, 08:05 AM
BDSford03 BDSford03 is offline
sounds like you may have forgot to connect something...
Old 08-23-2009, 08:19 AM
but i have got it to start 2wice since i brought it back home?? Thats what I dont get
Old 08-23-2009, 08:59 AM
hmm i have no idea then.... Maybe a tech will chime in
