Go Back   Ford Powerstroke Diesel Forum > Ford 03-07 6.0L Powerstroke Forums > 6.0L Problems Forum
Old 07-13-2009, 09:46 AM
arriero4x4 arriero4x4 is offline
Front end noise on 03 F-350 4x4, HELP PLEASE
Hi guys,
I was driving home last weekend and a strange noise appeared. i stopped and took a quick check and nothing seemed to be out of place. i continued and the noise appeared again, sometimes when i pass a bump, sometime driving straight. It sounds like something gets out of its center and then it stops.
Its not bearing because its not constant.
Its not engine because i shift to neutral and noise continues
Its not breaks because i started stopping and the noise was still there
Every part has the oil levels as recomended (tranny, transmission, axles, engine)
I took a look under the complete truck, there is no sign of something out of place, parts hitting or broken.
Any advice? ideas?
Thanks guys
arriero
Old 07-20-2009, 07:06 AM
It seems it's the locking hub. it's an auto/lock hub. Any idea on how to take it apart?
thanks
arriero
Old 08-20-2009, 11:53 AM
ok, i serviced the locking hubs, but the noise continues.....
it sounds like when the ABS starts working, but the speed remains the same, so its not braking.
I hope i wont get the front end locked in the highway.....
has any of you have had the same problem? A friend told me it may be the tranny is not disconecting....
thanks
arriero
Old 08-20-2009, 02:31 PM
BDSford03 BDSford03 is offline
pull the locking hub completly off the truck drive around and see if it is still there. I had a problem like this and then i put Warn hubs on.
Old 08-20-2009, 02:39 PM
just take it out? and drive around... i'll try today back from work. tomorrow i'll post.
Old 08-21-2009, 08:30 AM
i took out the locking hubs. i was unable to drive a block and the noise and shake was worst, so i put'em back in. i realized when i took out the hubs, they were "activated" or locked (in the auto position).
So.... are the hubs the problem or the bearings? the end of the outer axleshaft has some axial movement. is that normal?
thanks
Old 08-23-2009, 07:58 AM
when you pull them off there is nothing to lock in the axle shaft and the tires should be freely spinning on the Wheel bearings. (the Axle shafts should not be spinning.) I am not a expert but it sounds like wheel bearings.
Old 08-23-2009, 09:22 PM
thanks man. i didnt have much time this weekend to check the bearings. maybe during the week after work i'll check them out.
