Go Back   Ford Powerstroke Diesel Forum > Ford 03-07 6.0L Powerstroke Forums > 6.0L Problems Forum
Old 07-01-2009, 08:42 AM
biggish biggish is offline
rough ride!!!!
helllo everybody my 04 drw powerstroke has recently begun to drive like a lumber wagon i have a deck on her as i have a hotshot company so she run hard all the time 250km on the clock did a tire rotation and i was having trouble in the sterring found a lot of play in the wheel and alot of wondering and rough so i started with the shocks,my wandering is from my steering shaft but the rough ride is still there could i have gotton bad shocks or mabey to stiff they are monroes also since i did the shocks i get alot of vibration in the wheel when braking just did a brake job not sure where to start truck is just very rough tire pressure is good and front end is like new im very picky about my truck as i basically live in her so comfort is the key when driving but she shakes the hell out of me now and ideas as to where to sart thanks guys!!!!!
Old 07-01-2009, 11:27 AM
caryt caryt is offline
Get some Bilsteins.
Old 07-06-2009, 10:25 PM
DavidPhillips DavidPhillips is offline
You need to check the balance on the tires. You can sometimes tighten up a little play out of the steering box if it's not worn out. It's probably worn out.
When you replace worn out shocks you start to feel everything else.
