Go Back   Ford Powerstroke Diesel Forum > Ford 03-07 6.0L Powerstroke Forums > 6.0L Problems Forum
Old 07-01-2009, 05:22 AM
tekurtz tekurtz is offline
Send a message via AIM to tekurtz
HELP, CAN'T FIND BAD FUSE, IS IT A RELAY?
This morning I noticed that my signal lights aren't working, along with the overhead console. My hazards work just fine as do my brake lights. I checked everything else I could think of to see if there was something else not working. I cannot seem to find a bad fuse, is it a relay? or is there another set of fuses on the truck other than those under the dash? Thanks in advance for any help.
UPDATE: Now the power that feeds the vacuum pump under the hood is not energized, and no blown fuse for that. WTF is going on?
Old 07-01-2009, 11:33 AM
jcs jcs is offline
Check the plug for the multi switch in the steering colum and there is also a flasher/relay located in the dash kinda behind the radio and heater controls if you put your flashers on and listen and feel for it you should be able to find it pretty easy
Old 07-01-2009, 12:02 PM
6 months ago I replaced the signal relay with a Electronic LED relay for all 4 signal lights that are now LED. It seems to be functioning fine seeing as the hazzard lights work and the relay 'clicks'. What makes me think it's a fuse or relay is because the overhead console display with temp and such has no power. Is there another fuse box under the hood?
I'll try putting in the old relay to see if anything changes
Update: I put the old relay back in and it didn't do anything different. I found a fuse box under the hood with a few relays and fuses. The fuses are good. 2 of the relays are triggered when I have the hazards on, everything seems to be functioning properly there.
