Go Back   Ford Powerstroke Diesel Forum > Ford 03-07 6.0L Powerstroke Forums > 6.0L Problems Forum
  #11 (permalink)
Old 06-28-2009, 07:13 PM
2000 7.3 6speed 2000 7.3 6speed is offline
Originally Posted by Tree Killer View Post
Is that Sig Pic Legal? LOL I know it ain't in the buckeye.
Brought that tractor back from indiana. with close to an extra 1000 pounds worth on suitcase weights on the front of the tractor. haven't had any problems hauling it around yet.
  #12 (permalink)
Old 06-28-2009, 07:28 PM
rjwareagle rjwareagle is offline
Noticed mine on the pass side today. can you just push it back in? im on the road more than off road and roads in south GA are not to bad. ??
  #13 (permalink)
Old 06-28-2009, 07:47 PM
Scooter9495 Scooter9495 is offline
Send a message via MSN to Scooter9495 Send a message via Yahoo to Scooter9495
You will be fine i would just stay away from deep water and mud.
you cant push it back in the seal has actually torn into 2 pieces when they do that.
  #14 (permalink)
Old 06-28-2009, 07:53 PM
TANK'S 250 TANK'S 250 is offline
Like you said,...though it isn't recommended,...I still haven't had an issue with anything getting in there,...and I offroad alot,...water, mud, etc
yup...once it is in 2 pieces,...it's done.
  #15 (permalink)
Old 06-28-2009, 07:54 PM
Originally Posted by Mustang1989 View Post
About how much would a shop charge me to replace them? Am I safe to wait till just before winter?
I had my front U-joints replaced exactly a year ago. Are those seals something they would have had to replace to do the job?
They dont "have to" replace those when doing axle joints but for me i do them anytime the front axle comes out, its $24 for 2 seals to do both sides, its the outer knuckle seal thats pricey.
  #16 (permalink)
Old 06-28-2009, 08:02 PM
so its more work than its worth just to fix the seal? If there wont be any problem with leaving it, I will.
  #17 (permalink)
Old 06-28-2009, 08:04 PM
Tank, have you inspected the inside of your axle tubes lately?
Im curious as to what condition yours are in since yours have been bad.
about 3 months ago i did these seals on an excursion thats 95% street the owner said they were bad for about 2 years and the insides of his tubes were terrible, scale, rust,flaking (chunks of the tube) i got it all cleaned out but there were huge pitts.
Most of the other trucks i have done just have surface rust inside but i replaced them shortly after they failed.
After cleaning both sides i use a thin coat of grease on the insides of the tubes to slow down rust on the trucks i do.
  #18 (permalink)
Old 07-01-2009, 10:09 AM
GreenF350 GreenF350 is offline
Well, mine have been like that for a few years. Maybe I am looking at it the wrong way, but I haven't seen any other axles have those seals and they are just fine. Sure, it's nice to keep the dirt, water, mud, etc out of there, but does it really matter? I do think that it may help lengthen the life of the inner seals though, especially if you do have a bunch of dirt in there and pull the axle shafts in and out a few times.
-Aaron
  #19 (permalink)
Old 08-16-2009, 11:54 AM
Hank Hank is offline
C.P.A. Officer
Fellow org. member pointed out my flopping seals yesterday while I was doing a brake job. His are that way too. Seems to be real common?
  #20 (permalink)
Old 08-16-2009, 11:58 AM
Yeah, Most Superduties that I get to look at have them torn in two. Maybe I am asking for trouble, but like I said above. Most other axles don't have those seals and they work just fine.
-Aaron
