Go Back   Ford Powerstroke Diesel Forum > Ford 03-07 6.0L Powerstroke Forums > 6.0L Powerstroke Interior Discussion
Old 06-01-2009, 07:47 AM
bluestroker bluestroker is offline
Tournaments Won: 1
AIR CONDITIONING
ok so my Air Conditioning will only come out on the dash where the defrost is coming from most of the time after a while of running it will switch back to normal any ideas?
Old 06-01-2009, 07:55 AM
03f250stroke 03f250stroke is offline
vacuum leak
Old 06-01-2009, 08:04 AM
Tournaments Won: 1
ok so where do I start?
Old 06-01-2009, 09:48 AM
Tournaments Won: 1
Old 06-01-2009, 09:51 AM
Gator0175 Gator0175 is offline
My F-150 did that same thing, but it was under warranty still so I took it to Ford and they tested it and said everything was fine but it could be a vaccum leak Sucks when here in Florida when it's hot outside
Old 06-01-2009, 11:45 AM
Tournaments Won: 1
oh yeah well someone told me they think it might be the Air Blend Door Actuator anyone else have any idea
Old 06-01-2009, 12:50 PM
do you have on the fly 4wd?
when i had a vacuum leak in the 4wd it did the same thing. i fixed the leak and it fixed the a/c coming out of the defrosters
Old 06-01-2009, 01:40 PM
Tournaments Won: 1
yeah I do but I am having no problem with the 4wd
Old 06-01-2009, 01:47 PM
idk then man, i know it happened to me at the track the first time. then my 4wd wouldnt engage. so i fixed the 4wd and the a/c started working again.
but its odd that it happens and then like fixes itself
Old 06-01-2009, 01:51 PM
orng1 orng1 is offline
Maybe it'll help me figure out my issue.
