Go Back   Ford Powerstroke Diesel Forum > Ford 03-07 6.0L Powerstroke Forums > 6.0L Powerstroke Interior Discussion
  #11 (permalink)
Old 06-01-2009, 05:24 PM
tech10002 tech10002 is offline
You could still have a leak in the hubs even if they're still engaging. I'd highly suspect them as the culprit.
  #12 (permalink)
Old 06-01-2009, 10:30 PM
Gator0175 Gator0175 is offline
The hubs would effect the ac like that
  #13 (permalink)
Old 06-01-2009, 10:35 PM
Goose350 Goose350 is online now
Confused ?????
Mine was doing the same thing and a line was disconnected from my vac pump.
  #14 (permalink)
Old 06-01-2009, 10:36 PM
2005F250 2005F250 is offline
Vacuum leak. My truck has done this twice. It's probably a vac line under the dash.
  #15 (permalink)
Old 06-01-2009, 11:23 PM
ianstew ianstew is offline
Go ahead, swat the screen
There is a TSB on it somewhere....I think it's on dieselmann's site.
  #16 (permalink)
Old 06-02-2009, 04:57 PM
Coffaro Coffaro is offline
After 4 trys my deal gave up so I traded my 06 for an 08.
  #17 (permalink)
Old 06-16-2009, 01:47 PM
frioranches frioranches is offline
On the passenger side of the motor, there is a white vac line, located on top, you can't miss it, that probably came off. I have an 05 and I was having the same problem. It seemed to fix it so far. Another thing that seemed to help if that doesn't work, is turn the fan down, for a few seconds, and turn the temp to like 82-83 degrees. It usually comes back to the front and then turn it back cold and the fan back up. Hope this helps.
  #18 (permalink)
Old 06-20-2009, 04:54 PM
06pwrstrokerbullitt 06pwrstrokerbullitt is offline
This should help me I have the same problem. Defrost blows and usually I can turn the climate control off a few times and eventually it will blow out the vents. Also my 4wd is a little twitchty sometimes and won't lock, it does most the time but every now and then it won't engage, but the A/C never blows out the vents until a few tries.
  #19 (permalink)
Old 06-20-2009, 05:15 PM
kinghawg98 kinghawg98 is online now
a vacuum leak most likely.
I had the same problem (and it would sometimes switch to blow out dash) and found a disconnected hose.
See if you can you hear the buzz of the vacuum pump running for a long time...that'd be an indication.
  #20 (permalink)
Old 06-22-2009, 11:58 AM
HarleyMedic HarleyMedic is offline
Oilfield Trash
Had the same problem yesterday. Grey vacuum line under hood on right side came loose. Stuck it back on to plug it and it was fixed.
