Go Back   Ford Powerstroke Diesel Forum > Ford 03-07 6.0L Powerstroke Forums > 6.0L Powerstroke Interior Discussion
Old 04-25-2009, 06:43 PM
rjwareagle rjwareagle is offline
Dash lights are out 2006 f250!!
I got in today and noticed that the trans and water temp lights are out. the needle is still lit and the gauges work, but the lights in the back ground are out. what do to? Is this a common thing? how hard is it to fix?
Old 04-25-2009, 07:08 PM
is this something I have to buy from ford?
Old 04-26-2009, 06:56 AM
anyone had this problem?
Old 04-27-2009, 05:11 PM
Lbs Lbs is offline
Hmmm, never had this problem. Might just have to change some bulbs, I changed all of em in my silverado and it was pretty easy to do. I dont think it would be much different for these trucks. If you're gonna go through the trouble to change the lights I'd suggest replacing all of them with led's, they looked great in my silverado!
Old 04-27-2009, 05:35 PM
where do i get them? pull the old out and then see what they are?
Old 04-28-2009, 06:30 AM
HeavyAssault HeavyAssault is offline
My cluster has done the same thing since I drive a ton I'm betting the bulbs are loose. You can remove the cluster and pull the bulbs to replace as needed, the bulbs are found at any parts store.
Old 04-28-2009, 07:25 AM
cool, what about the led bulb that he was talking about?
Old 04-28-2009, 07:31 AM
Go to the "ricer" isle at Auto Zone....
Old 05-02-2009, 11:21 PM
Lbs Lbs is offline
Heres a pic of mine in my silverado, replaced all the green ones with blue.
[IMG][/IMG]
You can order them at superbrightleds.com, just find out what kind of bulbs you have and cross reference them.
Old 05-03-2009, 07:38 AM
arnt the lines on the gauges in the PSD green? or are the bulbs green? what color should I go with?
